Very nice Oz. Its making me excited watching your build come together knowing that mine is just around the corner. Still haven't got the manifold yet. So the gate you chose is all good hey? That intake pipe looks sweet as too man. thumbsup.gif
Yeah the gate size juuuuuust scraped through haha.
What u had it tuned at all-star, my car been there for 4 weeks and still haven't got it, grrr, good to see ur results, I'll be happy with that with mine.
Yeah I saw your car there.. haha im sure if it was a simple task like mine they would have had the car finnished, what are they doing to it?
I put a few bits and bobs back onto the car today heres a pic of the engine bay as it stands now.. just waiting on my catch can now i hope the guy i bought it off didnt do me a dodgy...
Mount Franklin catch can ftw!
GT35 on a fresh 26 into a gtst, so had to do a harness and vipec tune, so was happy to see ur results as I'll be pushing a few psi extra, and I got a little more head work,
Nice! you should be seeing around 550 if your planning on running 25 pounds :)
Its just the way GTR engines bays should look... BIg single and big nasty intake pipe :thumbsup: :thumbsup: Winning!
Haha right on bud, cheers :)
i will hopefully be coming along on sunday to watch a few of my tafe mates cruise, unfortunately not driving as i did not get my clutch done in time..................doing it tmorro ( > _ <) make sure u smoke "sydways" series 4 rx7, jahahahah :D any chance of a passenger lap in the gtr?..
Edited by drop2nd
hey man just pulled my intake pipe off last night after deleting my bov a couple of weeks ago to find I now have play in my tubo, both side to side and front to back. My suggestion is put the standard bov back on please.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
