On 21/08/2016 at 10:20 PM, R377 said:
The 255/40 and 285/35
FOUND OUT THESE WHEELS ARE Rays Gram Lights 57 Extreme Wheels  Great look for v36 sedan
 Wheels are 19x10.5 +43 all around with a 5mm spacer up front to clear the arms.
Trying to work out sizes and offsets available for as website is limited
RAYS GRAM LIGHTS 57XTREME
https://www.rayswheels.co.jp/products/wheel.php?lang=en&wheel=57EX_SP
19x10.5 +12    +25    +35   +43
19x9.5 +12   +25   +35    +43
Wedssport SA55  all 10kg in 19"
19x10.5 +15   +24
19x10 + 40
19x9.5  +15   +24
19x9   +38    +45
Wedssport SA15
19x10.5   +45   +35   +25  - 9.8kg
19x9.5   +45   +35    +25   - 9.5kg
then 8.5 inch
  Weds Wheels - Wedssports SA-15R in GBC (gloss bronze clear)
FRONT: 19x9.5" +25
REAR: 19x10.5" +45
Michelin - Pilot Super Sport
FRONT: 245/40ZR19
REAR: 275/35ZR19
Air Bag suspension
Edited by R377
  • Like 1
Wheel are Advan RS-D 19x9 +25f and 19x10 +25r. Tires are 225/45/19f and 245/40/19r so they are stretched.
Yeah I tried to fit the 275/35/19 in the rear but it the fenders were eating the tires even with -4.5 camber. I didn't want to pull the fenders so I decided to stretch instead. With the 245s I am getting away with -2.3 camber.
Wheel Brand & Model: VMR V702
Wheel Size/Offset: 19x9.5 +33 (square)
Tire Size: 245/40/19 (square)
Suspension Modifications: Ksport true type coilovers, front fender height about 26". Front camber -1.8, rear camber -2.8.
Looks great from the rear (no homo).  Not overly aggressive, would not need a camber kit to fit these wheels.
Forgestar F14 wheels 19x9 +32 19x10 +40 in gloss metallic silver. Wrapped in 245x40 and 275x35 PSS.
Clears Big Brake Kit by about half an inch
Suspension
I am set up on KW coils set at about 26.25 floor to fender, SPC front and rear. Running about -1 in the back, may increase it just a little bit, but fitment is just about spot on.
On 23/08/2016 at 8:22 PM, R377 said:
Velgen VMB5's wheels for v36 skyline sedan
20x9"F +30 offset with 245/35/20
20x10.5"R +45 with 285/30/20
Found some more photos   285/30/20 Hankooks on my 10.5" rears
7 minutes ago, R377 said:
front 9.5 +12 w 225 and rears 19x10.5 +22  w 255 on my sedan rears, was pretty low where it sat fender to lip on wheel, tucking tire and was running -5 camber. air bag suspension
Edited by R377
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
