  • Replies 45
i have sunline racing carbon fibre door trims going into mine,
i dont know if they make them for 4doors thought dude.
for ur car what i would be doing is basically stripping everything out from the doors, getting fixed lexan windows and just have an aluminium or carbon sheet of the door shell.
Edited by GUN_METAL_GTR32
Yeah I want to do this on my car as well but how do fixed lexan windows actually fit into the doors if everything is stripped out? Ie - where do they bolt on to?
Cheers,
Glen
Edited by xanavinismo
Cheers guys.
Was gonna go Carbon doors but to much of a head fu*k getting molds made/fixing if i crash etc.
Got a full Tarmac cage getting done in a couple of weeks.
I guess just stay away from the door latch area?
Cheers.
there is bugger all weight in the guts of the doors. The side intrusion bar is the only thing worth taking out. I've gutted a R32 door, and the window and mechanism weigh all of 1-2kg, and all the steel that was cut out was 1kg, they were a series one door. The only thing worth removing is the side intrusion bar (if you have one) as they are about 10kg per side on a two door, And if you gut them you need to still put some plates or steel cable back in to stop the door from sagging
I've started cutting and grinding the door, any tips to taking the intrusion bar out? I've made some slices in the steel tube but don't wanna cut to much cause I might end up through the door lol.
Cheers.
15kg without glass. The one I hacked ended up about 9KG
There was more steel to remove there is still a fair bit of double skin I could have swiss cheesed. MAybe another 1 KG.
Plastic fixed windows and a 0.6mm alloy door card wouldnt add too much back in.
Window winder weighed a tonne and so did the intrusion bar.
I still have to do this to my car yet :P
Pretty interested in how to fix the plastic windows in and maintain strength.
Edited by Tektrader69
Got any pics of the inside of your doors mate?
Did you have to put anything in the door to stop it sagging?
Cheers
Door was still plenty stiff as the outside skin still acts as a sheer web. JP might have some pics?
I think he went further after he got it. It was close to the weight of a glass door after he finished with it.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
