  • Replies 45
Has anyone had experience with the Bee-R carbon door cards?
Pricey but they look good quality. I am a little concerned they won't sit as flat as a simple aluminium skin, and might somewhat dictate side intrusion options for my cage builder. They look to have a similar shape to the factory 32 skin just without the armrest, pocket and speaker.
http://www.rhdjapan.com/bee-r-carbon-inner...-s15-ae86-54999
Yeah tell me about it - any local alternatives that you know of? I am sure I could sink the $1200 odd bucks somewhere else a little more useful.
Saw your beast out at racepace the other week - one of it not best looking GTSt around :)
Do you guys have cages? I do in mine and door trims just don't fit any more. I padded the intrusion bar and glued a soft backed carpet to the door.
A week or two off putting a full cage in. Stock trims definitely won't fit with side intrusion once its in!
I was looking at getting them when my car was in the panel shop, the price is each, so very expensive! :) IF someone can get a pair at that price then they are a little more attractive
thats not very expensive mate.
mine are worth over 2 grand
sunline racing japan mate.
there getting fitted shortly as soon as my carbon doors arrive :D
still have a nice streetable look to them as well, unlike the bee r ones
Edited by GUN_METAL_GTR32
They do look nice - they are definitely aimed at street cars though - far more intricate than the Bee-R ones which are aimed at caged cars.
The bottom of the sunline ones will interfere with cage side intrustion. My car is going dedicated tarmac rally and won't see the road so I want something basic and flat that won't interfere - Bee-R are the closest I have found in carbon short of just screwing a carbon or aluminium skin on to the door. $1.2k probably better spent on important things like tyres - saying that I will prob still get the Bee-R ones :)
Can't see the point of carbon door cards, may as well buy carbon doors and put in a thin aluminium skin or carbon fibre sheet.
Only thing is racing regs - tarmac rally panel modifications generally not allowed so have to run the standard doors. Carbon fibre sheet might be the go though.
Cool if you have 2k to spend on door cards, but in my books there is no way i can justify that amount of money to run door cards. Hell get some thin alcantara ro look alike material and just glue it to a raw door inner. Hell, way cheaper and lighter and more clearance....also give you the raw race car rattles :D
Cheers, its because I have not been around to bash it off tyres or set it on fire at the track the past two years :)
i have carbon doors on the way with a couple other body parts
my car is caged and they fit with my stock door cards so i dont see why these wont fit with it.
thats fair enuff i guess, but each to there own i like carbon lol
Thats all ive managed to do so far. Dont really know how far to cut. :whistling:
You can go a lot further than that around the edges. even to the point of putting the door handle on the skin and cutting the steel away.
Also swiss cheese the end on the latch side.
It is a dedicated track car isnt it ??
  • 3 weeks later...
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
