I've noticed since I got the 300GT, that occasionally, maybe once a week, when I shift it from Reverse to Drive, it will pause slightly before engaging.
So when I am reversing out of a carpark and I put it into Drive and accelerate slowly to get it around, it will hesitate for about a second and you get a light jolt. It only ever done this when the car was cold and had been sitting for a while. The transmission normally drives and shifts fine.
A web search gave me differing opinons; from it is normal as fluids need time and heat to work properly, worn shifter bushing, faulty solenoid to impending disaster.
I contacted Nissan and they suggested to do a service as this problem could be caused by dirty transmission oil. The oil level was good and the colour was a bright purple. Nissan did a service (flush, 9L Matic J, conditioner) and also informed me there were no error codes from the TCM. Problem is still there.
So does anyone else experience similar issues and is this likely to end up fatal?
Thanks
you shouldn't need to accelerate hard from reverse to D anyway.
and never rev the car hard after it's been sitting for a while.
just take it easy...if it drives fine when warmed up then dont worry about it.
Mine does exactly the same when cold, I wouldn't be too fussed with it if gear change etc is fine.
I'll take your advice, stick it in N for a sec before D.
Best to give it 30 seconds to warm up before reversing too.
i always put it in neutral for a sec or two after being in reverse, then into drive.
I was told if you go straight from R to D, you could blow the torque converter.
In the skyline/G35 forums, there is mention that grounding cables improve the gear shifting capability of the 5 speed transmission. Has anyone tried these to see whether it improves the engagement issue?
Also, an annoyance of the transmission in the 300GT 5 speed is its need to get into top gear quickly, obviously to improve fuel consumption. Is this a 300GT trait or does the 5 speed transmissions in 350GT and Stagea also experience the same thing?
Yeah I've noticed this as well but only in normal drive mode. Switch it to power mode and it behaves better, holding all gears longer, but obviously economy suffers a tad.
I'm in the process of designing a circuit to take "manual" control of the 5 speed auto and ditching the stock control module. I would like to have direct paddle shift gear changes as i'm sick of the time it takes for it to decide what gear I want, even in manual mode. The shift kit I installed helped the gear change speed but not the ecu gear selection speed.
Isn't that the purpose of any automatic car though?
To basically get you up into a high gear and keep your revs low, so a) your not revving the ass out of it and b) so you maintain fuel.
I was under the impression that thats why people came up w. tiptronic. To make it 'fun'
Ive got the GT8 and on the motorway at 110, its in 8th speed but if I was in tip mode I could easily be sitting in 3rd (with a heck of a lot more torque down there as well :whistling:)
Personally, peak hour it stays in drive. other times I have a bit of fun. Yeah it chews more fuel but the VQ loves it!
Mine has the 5spd auto and it never goes in drive unless I'm in a 50KPh zone. I always keep it in tiptronic, I think that being able to select the correct gear for a hill before hand instead of letting the automatic get lost in it's decision making process is a more economic driving style for me.
If I leave it in drive mode, I find that I'm more likely to tramp the gas in order to force it to make up it's mind about what gear is required faster.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
