  • 4 months later...
i did this once one day when i was bored (yes i get bored easily)... sounded fullsikwesidephat, or another words fuggen loud
reality is at idle it was hunting all over the place between 450-1600RPM & you can hear it leak slightly at full load. a good way to really confuse the ECU
hey guys this is prob a good time to ask this....
The compliance guys i took my car to last yr didnt block or take off the stock BOV and it has an after market BLITZ one on as well and the BLITZ doesnt even sound loud. Whats a good safe way to block the stockie.
Thanx guys  ;)
you have the same as me.would somthing like im suggesting be legal my question is why arnt there kits that cater for the top pipe to be replaced so there would be no need for stock bov,bov air return piping the pipe that runs from the elbow to plenum(would you keep it or is it possible to toss it?) plug intake pipe can it be done within law?
performance wise what is the efect it will give
you could also run a steel intake pipe.any suggestion for thought.
I need your suggestions because ive come across a deal with a neighbour who can supply me with the aluminium pipes.
hey guys
I did wat Nick said and bout a blanking plate....and damn thats alot better...not a single problem with the engine or anything...runs like a dream....im getting way better response too....now b4 4500rpm i get this lovely whirling wastegate noise and over 4500rpm i get this massive pressure noise which i looovvveeee :headspin: ....thanx nick man !!! :D
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
