Clutch Power Ratings?
Just doing some research into clutches
Just wondering what power ratings some clutches are
Mainly looking at NPC and Exedy for the moment till i get emails back from other places
Car is 194rwkw atm but will be chasing about 290rwkw (Prob at the most) later this year or next year
so probably a clutch good for 300-320rwkw?
If anyone can tell me what theyve come across, what there using and what they would recommend it would be much appreciated
BTW: Car is pretty much 99% street driven, occasional 1/4 mile runs for a bit of fun, maybe 4 times a year at the most
It has an EXEDY cushion button clutch in it atm that has lasted me 2 years and has been a good clutch, has only just started slipping now and im not sure why, pretty sure it was good for 260kw and I have less then that but anyway
anyways, thanks in advance for any help
Callan
my advice for 300rwkw rwd, exedy organic will be good enough and it'll still drive like a normal car.
if you want to slide it maybe consider a cushion button clutch..
I wouldn't know about Exedy in particular, but my experience so far has been bad with organic clutches. Earlier this year, driving sedately at 60 on the way home from work running a max of 174rwhp mine slipped and quickly died.
I'm looking to crack 300rwkW in a few weeks, in the same scenario as you and I'm running an RPM ceramic at the moment, the heaviest they make and I'm very happy so far. Although I'd like to have gone exedy/Jim Berry I just picked this one up because my girlfriend's parents supply 'em and it was cheap.
Just ordered an NPC 10" Sprung button clutch, sounded the go and wasnt overly pricey :down:
Had a few mates with NPC clutches that reakon they were good so ill see how this one goes, Thanks for all the advice, ill try and remember to post how the clutch goes
Hi guys
Just in case anyone was interested.... I got the clutch in last night and have started driving it and its actually suprisingly good
I was expecting hard pedal and jerky button clutch engagement but it feels nearly as light as my stock clutch! much lighter then the exedy cushion button i had in there before. And its pretty good in terms of engagement, i can do a pretty normal take off from the lights already
Its still got that bite of a button clutch but compared to the last time i drove button well im really impressed
If anyone wants to know it was:
NPC 10" Sprung button Clutch (R33 GTST)
Im very happy with it :wub:
Callan
Really? The guy I talked to was pretty helpful and I had a chat for a bout 15mins to work out what clutch would be best
helpful yes,
my clutch failed and they failed to accept responsibility
then they beated around the bush trying to point the blame on contamination
bah, i just went to another clutch joint. dime a dozen
I'm making 250rwkWs and using a hybrid kit
- R32 GT-R 1.1 tonne Exedy Pressure Plate
- R33 GTS-t Sport Ceramic 3-Puk Clutch Plate
- R32 GT-R Nismo Big Bore Clutch Slave
- R32 GT-R Nismo Pivot Point
Car is quite easy to drive, some chatter and I abuse the shiet out of my clutch, holds well :banana:
 Share
