It's funny to see how many people are as lazy as me with their radio :P Who listens to radio anyway?
HAHAHA..so true...y bother spend money on listening to music when you can listen to the great roar of your car....i rather spend that money on performance...
ahh well there will be a few of us..will just hit lygon or somthing :D
i am with you for tht one bro...lol...ya will have to plan a plan B if its out of our range....
  • Replies 165
Ive just gone and printed 25 maps of the route which I'll hand out at the car wash.
Also for guys worried about their stereos, im pretty sure they give out personal radios there if your car wont take the station, at least that is what they did when my battery went flat.
lol I would have spent the whole movie wondering what to do about my flat battery situation when the movie finishes :P
Damn James! You beat me to it! :) Yeah thanks Adam for awesome organising.... and thanks to all who helped me with my sound needs, next time I might bring the Subi. Cool flick ^_^ Can't wait for the next one!
Great night, good turnout, thanks Adam for organising the event. The movie took some time to grasp together but I managed only when you check with fellow sau members next to ya to ensure of what's going on lol. The portable radios given were crap quality and had an issue with the sound which distorted sometimes.
Was a good movie and night. :)
With the ending I think that he did wake up to reality because his spinny thing did slightly start to wobble and you will notice that through the movie in his dreams he never saw his kids faces, but at the end he did. My 2c.
Cheers guys, i enjoyed the movie as well. Jess doesn't remember that much of it :( she was dreaming while watching inception while they were in a dream.... weird.
Pissed that the manager guy who had called me 4 times in 2 weeks somehow did not pass on the info to the rest of the staff, will talk to him about that for next time.
I think the night went well though, i'll plan another shortly.
Also, I reckon he was in his dream and his kids were projections.
Great night guys, I thought it was a fantastic movie. Makes your head spin a bit but I think that's a nice change from the usual "blow everything up" action flick.
I love ambiguous endings like that, gives you something to think about afterwards.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
