I dunno if it's gonna be the same in WA, but in NSW the engo accepted that Klippan non-inertia reel seatbelts were okay, front and rear.
At the back, you'll find that the c-pillar sheetmetal and floorpan will already have seat belt mountings behind the trim
At the front, it's just the regular Klippan kit, but with the longest available stalk buckle (i think 450mm, cos the mount is so far back on the tunnel).
Umm...apart from seatbelts, I think I didn't have to change or add anything else for rego/engo. Tail lights and indicators (which blink red) were ok for the age of the car.
I think the only hassles I had on rego were things like noise and ride height :)
cheers bro i luv it how i can just copy you :P
  • Replies 56
Ahh, so you bought Jash's car? Awesome project :) The KGC10 build thread on PF is my car, whaddya need to know, Denzo? :)
Oh and btw the issues I had with the L-series were 99% caused by the person who built it in Japan. We ended up starting from scratch, and the cylinder head was redone by Knight Engines in Adelaide, and Nathan did the bottom end and assembly. Ran sweet as a nut after that. Puts out 190rwhp and sounds great, so yeah I'm happy with it.
Every single L-block I've worked on has been assembled by some clown that did it wrong. Be it head geometry, distributor timing or general coolant or air plumbing - people just didn't seem to put in the effort (and probably assembled it with no reference materials).
It's always a wise idea to tear any engine like this down for inspection, because you can never really sure what you've got...
An L-6 can easily produce 150% of the OEM output practically forever if it was put together and maintained with care. I've pushed 200% OEM in one L28 via turbocharging for a decade with no mechanical failures.
In my case, the list of things were....
- wrong inlet manifold (the head ports were bigger than the flange = air leak)
- carbs set up for 2L, not 3L :)
- carb linkages set up all wrong
- ignition wiring problem (coil wasn't getting full juice)
- dizzy cap worn, electronic module wasn't earthing
- 2 dud plug leads
- wrong crank pulley, didn't match the timing marks
- mystery cam timing that was 1/2 a tooth out
- MASSIVE cam that wouldn't have worked below 6000rpm anyhoo (278 degs at 50 thou lift!)
- insufficient fuel pump flow
- butchered sump baffles/oil pickup/mismatched dipstick
...and prolly heaps more I've forgotten :) So I'd find one fault and fix it, then be scratching my head wondering why it still drove like crap :D In the end, I tried to fit a street cam to it, and then realised that the retainers, valve stem heights, etc were all non-std. So that's when I threw in the towel and as you suggested, started from scratch. From the first 100m after the rebuild, it was a totally transformed car.
But in the end we got lucky...it turned out the motor was a very recent 3L overbore with 11:1 pistons and heaps of headwork, so all it needed was a freshen up and it pulled 175rwhp straight off the bat. With a bit more tuning it's at 190rwhp currently, so it's all good :)
I guess what must have happened was that the previous owner in Japan started collecting cool parts, then ran out of time/money, and then everything was slapped together very roughly and the car flogged off to be someone else's problem. But the L-series is a great motor to drive behind, tons of grunt, tons of personality :D
I just bought this on Import Monster as a reference come memorabilia item. Should make interesting reading.
http://www.importmonster.com.au/view?url=h...%20KPGC110%20S5
D
A couple of really good books to get if you are interested in the Hako, are:
G-Works KGC10 Vol 2, which is more on the modified Hako side, got lots of info on wheel sizes, parts available, etc. Not so much of a book on the 2000GT-R but more of a modifier's guide to making a GT-R clone/hotting it up.
http://www.g-works-web.com/?tag=kgc10
The other one is C10 Complete Book, which is purely a reference to the stock cars, so it's chock full of catalog scans, colour charts by year, differences in the badges etc by yr, differences between the variosu trim levels, etc. Pretty good if you want to create a realistic GT-R clone, since it has all proper info on the real thing.
http://www.geibunsha.co.jp/shoseki/car_c10skyline.html
If you're in Sydney, the Kinokuniya bookshop has copies of both, the last time I was there
Edited by Babalouie
  • 1 month later...
Danny
My old man had the seat belts in his old 180B SSS replaced with inertia reels. They would have originally been a similar setup to the '10. They even matched the blue colour of them and are much nicer and period correct than the plastic Klippans.
Will find out where he had them done if you're interested. Here's his beast:
http://www.sillbeer.com/2009/02/dads-datsu...-new-shoes.html
Cheers
Brendan
Edited by VSPEC32
  • 3 months later...
got a c10 coupe as soon as i pay for it , will you take a shopping list of of bits needed (second hand and aftermarket ) ? ,and which aftermarket companies do you deal with ? ( fibreglass panels etc ) . ta will
  • 7 months later...
  • 1 month later...
What do ya know.......its back from paint. my legs seriously went weak seeing it in person.
The job looks great, pity about the mess around with the other guy or there'd be more progress.
Interior is out getting finished and everything else is stashed away ready for after-pits mods.
with his j-land contacts, the collection of awesome rare parts denzo has collected for this will blow you away.
Stay tuned for more progress, will keep updating the site with photos as i get them. Sorry bout the iPhone quality.
http://japaneseperformancecentre.com.au
I'll get better pics from danny next time i'm down.
(The email attachments didn't work mate.)
Socrates, I know of a really good L series builder here in Perth. Same person who used to tune my webers.
Put the info up, will be handy for others who stumble across this post or searching the site. Does this person do L4's and L6's?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
