These parts are off my stripped black 1994 r32 Skyline Type-M with 64000kms. Negotionable prices listed for more major items, too many parts to list prices for so just make me an offer on others. Payment by COD or direct deposit. Large parts pick-up only, located on the Gold Coast.
Interior
Roof lining $30
NAVAN steering wheel (no boss) $30
Din and gearshift surround (removeable part SOLD and whole dash section available)
Instrument cluster surround (with wiper and headlight controls)
Glovebox
Rear seat
Carpet $60
RH door trim
Digital climate control and loom (no cover)
Map lights
Driver's window and mirror controls
Indicator stalk
Accelerator, brake and clutch pedals
Centre console (section between seats with storage)
Rear view mirror SOLD
Sunvisors
Bonnet cable
Exterior
Manual diff centre $220
Complete left door with glass and trim $100
Front and rear wipers
Left taillight (no surround)
Numberplate lights
Left fog light
Damaged boot with spoiler
Engine
R32 turbo (64000km, minimal shaft play) $320
Brake booster $40
GTS4 intercooler $50 SOLD
Steering rack $60
Carbon canister
Gearbox speed sensor $25
Driveline
Unknown coilovers (stamped "JAM JTB1020")
Manual tailshaft yoke $120
Castor rods $45ea
Type M discs and calipers (front and rear, will sell complete only) $500
Complete rear craddle with driveshafts (has bent right wishbone and upper support) 1 driveshaft sold
All hubs
Front upper and lower control arms (both sides)
Front and rear swaybars
Other
Ca18det stock intercooler $40
ca18det radiator $70
Turbosmart boost tee (bleed valve) $60
PM me or email [email protected]
https://www.sau.com.au/forums/topic/32880-many-many-r32-parts-for-sale/
  • Replies 56
complete dash is sold sorry. not sure about the coilovers. one of them had a knob with numbers 1-6 on top when i bought it but lost it taking the car apart. i assume that is damper adjust but i won't give any guarantees. as for height adjust i'm not sure.
Interested in engine, discs, calipers and brake booster, and the steering wheel. Can you PM me a package price and also cost of shipping, methods of shipping you are willing to entertain and also how quick you can get the parts off and ship?
I'm waiting on an insurance claim for my front axle, but would you happen to be able to get parts off that too so I can get it off you as spare parts for insurance work?
Cheers,
Shan
Neil,
Is the clutch pedal attached to the pedal box, coz mine just crapped itself tonight.
Let me know how much (incl postage to Melb)
Thanks
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
