  • Replies 111
Potenza RE-71 225/50/16 were the sticky tyres that Bridgestone developed back then for the GT-R. RE-010 for the V-Spec.
Next Q. Do you know what the 1st prize will be for the "Best R32 GT-R" at the R32 GT-R 21st Anniversary event next month, besides getting an Award Certificate signed by Terry Ashwood? :P
This will have to be confirmed at 100%, but apparently the late R32 GTR's (>2/93) share the same engine as the R33 GTR's, including the crankshaft with wider oil pump drive and the pull type clutch setup.
absolutely correct....in fact I pulled apart a 94 R32 on the weekend and it has pull clutch and long oil pump drive. also had what I would normally call 33 gtst calipers instead of the similar but different external r32 gtr calipers. few other wierd things too.
Did you know that there were:
~Standard Cars = 40,390
~NISMO Group A Evolution = 560
~V-Spec = 1,453
~V-Spec II = 1,303
~N1 Race Version = 228
~43,930 in total produced of the 32 gtr
~Originally only 510 were suppose to be made to be within the rules of Japans Group A racing but demade was so stong that they released the model for unlimited production. Hence the 560 for the Nismo Group A total.
~Production of the Gtr started out in May 22, 1989
~The first Gtr was produced in February 4, 1969 know as PGC10.
This is an awesome thread and should be sticky'd as well.
And what was the date of the NISMO Version release?
Did you know for the Aust. R32 GTR there was no reverse lights beside the rear number plates, replaced the indicators as reverse lights, and so the outer brakes lights made orange.
I googled them. Australian delivered R32 GTR tail lights are here: https://cars2.ebay.com.au/NISSAN-SKYLINE-R3...bayphotohosting
Did you know that...
The R32 GT-R 21st Anniversary Cruise is on next Sunday 10/10/10 from Tench Ave Penrith????
Watch for the big NISSAN sign! R32s should line up well before 8.30am if you can! 1st group leaves at 10am. Have brekky at The Coffee Club.
See you there!
Group #1 Cars will be R32s
Group #2 Cars will be R33s
Group #3 Cars will be R34s/R35s/Zs/Sylvias/Stageas/V35s/Cefiros/Cubes/Datsuns and other Nissans
Group #4 Cars will be any others; and you're just as welcome to enjoy the highlights of the 1992 Bathurst 1000 at the Edge Cinema Katoomba at 1.30pm
Anyone wanting to hoon, STAY AT HOME > and watch the V8 bathurst instead of THE RB BATHURST. Only law-abiding drivers/families are welcome.
Tix are $15 with all profits going to The Children's Hospital Westmead and SAU (nfp). This is a FAMILY DAY.
Photoshoot opportunity of your pride 'n joy for $50 if you're a Member on the day. > See thread by Pezhead. Pro shots by MaTBoY and Kory.
Mr Samo - the J-Spec GTR's actually produced less power than the Gibson Motorsport GTR's.
When Gibson order the GTR's, they cam race prepped with 500hp Nismo motors etc, and Gibson played with them and bumped them to 600hp.
Gibson Motorsport were invited to compete in Japan with their GTR's (against other tuner GTR's), however Nismo told them not to come as they would annihilate the competition.
^^^ The NISMO vid posted in this section shows the Gibson cars starting life as standard road cars then built. Not from NISMO.
Also NISMO's own cars were slower than the Gibson ones, that's why they weren't allowed to go :(
5 internets to anyone who can tell me when the last run of R32 GTR's was, what colour and how many?
5 more internets if you know what the luxury skyline model was called when first released, and who designed it (if you work this out, it should give you a hint to the first question)
A. The Infiniti G by Hiroshi Hasegawa
And what are "internets" anyway?
I would guess then Hiroshi Hasegawa did the r32 gtr too and the were white and about (from wikipedia) 2756 of them.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
