Want to know what coil-overs will fit into what cars? Can't see the search tab? Lol. Try the following.
http://www.skylinesaustralia.com/forums/Te...,+shocks,+shock
http://www.skylinesaustralia.com/forums/R3...gable+coilovers
http://www.skylinesaustralia.com/forums/R3...=coilovers,+fit
http://www.skylinesaustralia.com/forums/Co...=coilovers,+fit
http://www.skylinesaustralia.com/forums/Gt...=coilovers,+fit
http://www.skylinesaustralia.com/forums/33...=coilovers,+fit
According to the threads above, the following coil-overs should be interchangeable:
R34:
R34 GTT and R33 GTR
R34 GTT and R33 GTS-T *front only*
R34 GTT and R34 GTR
R34 GTR and R33 GTS-T
R34 GTS-4 and R33 GTS-T
R34 GTS (non turbo)and all R33?
R33:
R33 GTR (BCNR33) and R33 GTS-4
R33 GTR and R34 GTT
R33 GTS-T and R34 GTT *fronts only*
R33 GTR and R33 GTST *fronts only*
R33 GTS (non turbo) and R33 GTS25-T
R33 GTS-T and R34 GTR
R33 GTS-T and R34 GTS-4
R33 and R34 GTS (non turbo)?
R32:
R32 GTS-T and R33 GTS-T *front only*
R32 GTR and R32 and GTS-T *fronts only*
R32 GTR and R32 GTS4
NOTE:This isn't my information, just collected threads with the intention of helping people looking to buy coil-overs. I'm simply trying to find what coil-overs will fit into my car (94 S1 R33 GTS non turbo), and ended up with this thinking others might use it considering i've found 16 relevant topics on the same thing, and there's alot more as I only did a few basic searches to get an idea. There's so many contradicting statements and "fronts will, rears won't", different mounting types, and the fact that the above is just based on bolt-in fitment, nothing to do valving, spring rates etc. I could ramble on, but I think you get the idea that i tried to make this as a guide for people, as per the topic description, and i'm happy to edit the post if people can add things such as "I bolted R32 GTR front coilovers into my R34 GTST no worries",and also as I get more motivated to sift through the remaining topics from more searches. But honestly, the whole thing is a head f***, so just buy coilovers to fit your car and be happy. :blink:
https://www.sau.com.au/forums/topic/328957-interchangeable-coilovers/
nice thread, ive been thinking this section needs a compatibility thread for a while now, not just coilovers either. should sticky it
Cheers mate. Any help appreciated in making it more accurate, as stated above, as at the moment it's just a few posts correlated into a list. If people could measure and post up the factory upper mount type, stud number, stud pattern and distance, as well as lower mounting description/type i'll edit that in too.
And can someone with a R33 GTS non turbo confirm that R33 GTS-T coilovers/struts will bolt in? I'm having difficulty finding any listings other than GTS-T stuff. I just want a basic street spec damper, non-adjustable to avoid getting the wrong kind of attention, that will take a 30mm King spring lowering spring. Instead I ended up with this thread. :(
R32:
well i can confirm these, 32 also fits Aus spec R31 rears.
the R33 stuff sounds right if i remember right, but my memory is too shit to say a definite on it.
R34:
R34 GTT and R33 GTR
R34 GTT and R34 GTR
R33:
R33 GTR and R34 GTT
R32:
Ok, as I read it:
R34 GTT and R33 GTR
R34 GTT fits R34 GTR
R33GTR fits R34 GTR
R34 GTR fits R33 GTS-4
But then R34 GTR fits R33 GTS-T.... and then etc etc for R33 gts-ts
Is that right? So R33 GTS-T fit R33 GTR, because R34 first R33 GTS-T :):down:
R34:
R34 GTT and R33 GTR
R34 GTT and R34 GTR
Issues i see here is you say r34 GTT and GTR are interchangeable but then say GTT and r33 GTST aren't fully interchangeable but the r34 GTR and R33 GTST is seems like something might not be right there
R34:
R34 GTT and R33 GTR
R34 GTT and R34 GTR
Yeah mate, I just went through a heap of posts and ^listed^ what I found, like I said at the bottom I don't know if any of the information is accurate, and I didn't cross-reference either. :D
  • 4 years later...
So has this list been re edited? Just looking at getting some tein coilovers for my R34 GTT but they dont offer the ones i want but they do in other skyline models. Sorry to revive an old thread or if theres a newer one please point me to it
With r34 gtt you'll need r33 Gtst front shocks and r33/34 gtr rears, see if you can just order pairs instead
R33/34 gtr fronts will also fit, but not recommended only because they are roughly 20mm shorter shocks standard with higher rates.
Not sure about those teins since they are height adjustable plus the shocks are designed to run much higher spring rates anyway
that is front n rear?
yes, both fit. Currently running a set of hks's in mine to suit bnr32. Only difference is pillowball mounts, r32 is circular, z32 is oval so may need to trim an r32 set if fitting to a z32.
edit: Pillowball difference only applies to fronts too
Edited by lidz
or get r32 mounts? if gettin a z32 coils. How about the koni shocks for the z32?
Edited by omnigear
Little unsure what your asking.
The issue is the r32 circular front pillowball mounts tend to be a bit wider than the oval z32 ones (but not always so test fit beefore chopping!) so will not fit against the inner side of the guard. Thus one side of the mount needs a slight trim.
Z32 coilovers however should fit into a bnr32 or gts4 with no issues at all.
Edited by lidz
  • Like 1
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
