I have the hks 2835 pro s turbo on my car. Happy enough with the power. Most I've had it at is 267kw @ 15psi. Didnt want to strain the turbo too much after blowing my last one. Happy with the power and the lag.
Also as far as im aware hks have now brought out the 2835 kai turbo, which I believe is an improvement on the pro s. If you really want the 3076r I'd talk to Mick as well, as he is running it on his 25.
edit: one of the reasons I went with the hks turbo, was apart from the heatshield it pretty much looks factory, and is a direct bolt on.
  • Replies 100
Given Kris' claimed results on an internal, and the mention of police attention (I haven't been looked at twice by cops since I bought the car....first 5 or so months it had 5% tint all round so go figure) I'm leaning towards internal a little more at this stage, depending on just how much more external will end up being.
v66 still runs wasted spark I believe....unless I missed the part where they changed it. It's just the v44 but plug-in
EDIT: you said injector not ignition, my bad.
Edited by Trozzle
having made a boo-boo and ordered an EXTERNAL pump, not INTERNAL like I thought (bloody hell 040 and 044 look the same at a glance hey...) I'm now going to be receiving something I can't necessarily use all too easily. Can anyone point me in the direction of info regarding what's needed to use an external pump in place of an internal one? Might as well go with my f**kup now and use it, if it can be without too much trouble...
This is what you want...Bargain
Garrett gt3540 / gt35r bolt on turbo kit.. $2100 ono
.70 front, .82 rear, great condition - looks brand new, no smoke or oil residue anywhere, minimal/negligible shaft play
Includes Highmount manifold, 3" dump/front pipe & o2 sensor, braided oil feed line, water lines & fittings, external wastegate w/ screamer, stainless intake pipe to AFM, hose clamps & reducers, everything in the pictures! Can ship it anywhere in Oz
http://www.skylinesaustralia.com/forums/Wr...ts-t328761.html
Hey krayzie he could get that but the lag is just too bad on a 3540, i was considering upgrading my turbo to that but everyone kept saying its not that good for street due to the lag. There is a reason why many people say that the 3076R is the best turbo for the rb25 for street.
Heres my dyno sheet for my claimed power.
Im sure you will be able to get it to fit internally, just might need to customize the bracket to where its mounted too.
044 on factory rail
sweet, yeah I read into it quickly now that I'm home, and it can be mounted internally....just with modification to the bracket. That's ok with me lol.
And thanks for the dyno sheet man, makes me happy to see that work so well with internal gate etc
I'm not even after top end too much anyway, so a small drop up the top doesn't phase me. I realise that since I'm not after top end, that means I'm after response and pull...which is better with an external gate anyway :( either way, can't wait Kris I know I'll love it :D once I sort out how you have to mod this bracket for the 044 >.>
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
