Should look at rotas :) they are good value fark 10.5 on a GTST, I wanted 10.5 but couldn't get them are you sure you can pull off 17s as well as 18s? might look funny on a 350z looks ok cos of there fat ass's we shall see though :P
Yerp they'll fit!! otherwise ill make them fit!
Already payed for new wheels, just waiting for them!
I remember your car from show n shine a few years back, and also a cruise to phillip island all i remember is the sound of that beast!
cheers mate ;) it did frequent the major SAU cruises in the day, have been a little slack lately :) but cheers again
