I'll do it this week. Will be purchasing some lock tight and a special key haha.
Just be careful if you reuse the standard bolts, make sure your torque rates are correct and that you tighten them in the correct pattern
I would use new bolts myself
It is just a 12 point 8mm and 12 point 10mm iirc
So BBS would have designed it this way to give you an option. Very clever!
Just make sure you align the face exactly dead center
I re-used my bolts and they still run fine, it is just a matter of not over tightening them
yeah spline bits 8mm and 10mm
Well I've still got my standard bolts, but I went gold anyway. So I needed new :P
Same here when I put the Panasports in, every time I'm on break at old work, used to go to the car park and stare at it, usually have shoppers stare at it as well!
yeah they are definitely a set of wheels which could make alot of cars look awesome i think!
Ive thought about buying some other wheels just to keep the panasports immaculate lol
top level of a carpark on russell street right next to billboards
took like 5-10 minutes to make it up there cos the ramps can be a little steep at times :/
Ah yeah, I know the one.
Tight ass carpark will all the corners.
But you would of had to pay for parking when you leave yeah LOL! Pay money to take a photo of your car :rofl:
Lol I did have to pay! But I was having lunch in the city with a friend so was already parked and took them when I came back to the car lol :P
Im looking forward to some sun to get some nice pics of the purple colour!
Looks great Aaron. There's nothing like attending a meet and getting free "professional" photographs :P
What's that little black thing attached to the front bumper and the fender on each side? If it's holding it all together, I might need one too :X
Lol amen to free stuff! And thanks!
Yeh they are latches holding on the front bar, ripped it off at sandown lol. But don't regret doing it at all. It takes me like 30 seconds to get the bar off now.. There are still 2 screws under the grill so the bar isn't getting stolen either lol
Was like $25 from auto barn
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
