Car used to have ztune front on it!? Old owner sold it I guess? Would have been awesome if you got it.
I negotiated a price that did not include the Z-Tune front end.
Would love to have kept it as it is all Genuine Nismo, but dont have the $$$
Also changed wheels to 19" TE37 as the SSR's need spacers to clear the brakes, where as the TE's clear them.
Other than that, it is all as per the photo.
Edited by HIRISK
haha that's some old school shit man. Even before my time by about 2 years!
If you want back into the email (that's how it's all done these days) - PM me an address.
Warning you though, there can be 200+ per day between the 20+ of us.
It's hilarious (and we are having a meet next week) ;)
Moh you seem to have gone to alot of effort to make a rather boring looking car..
I was expecting more radical..i think it needs some fluro pink wheels
hahahah because mohsen.
That was the goal though, build something that doesn't scream out look at me.
I've had people look twice at it when I told them it was a wide body.
would want it like that anyway... Since the 30 will be going in in a few months
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
