Ye looks hot. Thanks ;)
http://www.carsales.com.au/dealer/details/nissan-skyline-1998-12923190
Thoughts? Power Rd Dandenong - heard neutral things about them. If anyone knows more about them, private message me please.
I'd import if I were in your position, unless you can't wait for a car?
Why would you wait 3 months to import a non turbo auto 4 door 34? You wouldn't save any money and you wouldn't really end up with a significantly better car than anything already here.
Someone post a good looking R34 sedan before I completely change my mind about buying the one I have my eyes on :(
Clearly you don't get out much there's eleventy billion 34 auto n/a 's driving around not to mention on carsales
Why import ?
Kbro. And I'm not going to import, was just a suggestion - I am looking to finance ~ $10k, so Carsales has proven to be pretty linear in terms of variety. I'm pretty sure I will be going with what I have chosen assuming it ticks all the boxes ...dem underbody tar sneakies.
Edited by Cevzy
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
