I totally agree with whatsisname. I am expericencing the same problems with my stock ECU as its starting to show its limits. At a dyno day, the graph was climbing rapidly, then it nosedived by about 30kw, then rocketed back up to close to 170rwkw. There was no doubt the ECU was pulling timing badly. On the road, it was like I was backing off, then flooring it again. After that, the curve was smooth again, with 1 deg less on the base timing. I am thinking of doing the knock sensor mod so the ECU doesnt panic all the time..
in regards to the AFR's, on graphs ive seen with the stock AFM, the line is more up and down and messy looking before leveling out in the top end. I just had my car tuned with a Z32 AFM and the AFRs are HEAPS smoother and flatter. Maybe they are easier to get consistent with a Z32 AFM? i dont know. i dont really care either, as long as its safe and the car goes hard is all that matters!
Well done, new found power is awesome!
Enrico,
Why can't shootout accredited dyno's be compared? I take it this was a Dyno Dynamics dyno? I've seen hundreds of cars using 4th gear and they don't hit the speed limiter on the dyno, what's different about there's? I totally agree that dyno's are a tuning tool, and that aslong as the tune is good then that's all that really matters, but it's nice to have a final reading in shootout mode so that we can all compare figures without dyno bias.
enrico i doubt your AFM is maxing out at that power. With the boost your running and the power your making it should be absolutely no problem. My stock AFM only maxed out running 18psi boost on a cold night. I could almost get away with running full boost in warmer temps with the stock AFM. Mine with the stock AFM made around 230rwkw without maxing out (unless cold air temp).
Seeing as Z32 AFMs arent real cheap, plus if you do change it, you will need a retune on your uni chip, id be sticking with the stockie until it brings you problems.
Steve is their a way to work out what voltage the stock AFM is running out without getting a fancy aftermarket computer ?
Also remind me please, what is the peak voltage again for a S1 AFM ?
peak voltage is the same for all AFAIK, S1, S2 and Z32 - 5.115V, not sure how you would check it sorry, must be some way to measure the ouput though
the difference between skyline and z32 is what airflow produces the same voltage, z32 will flow more air for the same voltage reading as a skyline afm, so for example (figure purely for demonstration) the airflow for a skyline afm may read 5.115V, but the z32 may only read 4.25V. thus greater tuning ability at higher airflow
Gts-t Vspec, I will be gettin a figure from tilbrooks when the boost is upped and cam gear is dialled in. But until then, u will have to wait. Of course I would like a dyno read out in shootout mode, cos i know on this particular dyno, it is one of the lowest reading in SA. So obvioulsy i want a higher reading :D So i can compare to u.
Also, how come whatisname commented that our dynos were very similar in curve, then he mentioned that he was maxing out afm. Thats what has gotten me confused.
Another thing, Last night while driving (9ish), the car felt good, but when i was drivin another hour or so later (11.30), it felt awesome, like heaps more pulling power. Could this be what you guys state at maxin out afm, or would i feel it in a jerk of some sort. Or it could of been cos the colder air..
Do you know if anything can be plugged in on a dyno and tested that way? I wouldn't mind knowing what mine is running at just to see if its causing a bottleneck.
A real budget way, is next time you are on a dyno, just use a multimeter to measure the voltage output from the signal line on your AFM...or perhaps more conveniently get a cheap batter voltage gauge (Jaycar???) and wire it up, you will soon know what its peaking at, some of the cheaper voltage gauges may even have a peak recall.
Haha the thing is Benm, u cant compare dynos, just how u have experience with some readin 203 for u then others at 180...
I dont see how people can still think they are compareable. Anyway, ill just use my digi multimeter and see what happens on a dyno run.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
