  • Replies 53
G`day mate what do you want for the injectors? Will they fit a std. R32 fuelrail? Call me on 0438 067797 adam.
hey guys, sorry for lack of response. I'm moving house at the moment and have now shut off the phone/net at the old place and of course they still haven't connected the new place. so pls bear with me over the next few days while it gets sorted.
anyway the sard injectors are $700. which ever of you guys is still after them just send me a pm.
ps. yes they will fit a standard R32 GTR fuel rail. in fact they will fit any model GTR fuel rail. will not fit GTST.
I also have a sard fuel rail to go with them. also brand new and allows you to run it dual feed (feed at each end of the rail and the fuel reg in the middle, much more even pressure distribution).
hey guys. still got engine to go. 1 week left till I'm away for a bit so if anyone else has an offer to make or wants to check it out, now is the time. I'm a bit flexible on price at the moment with holiday looming but once I get back price will firm up again. don't sleep on it!
  • 1 month later...
yeah the base NUR engine when available was about $16,000 but you cannot buy them any more. check the link above (no longer available and no longer listed for sale).
this was a $16,000 base engine, then about $3,500-$4,000 in head work and other labour (all the disassembly, re-assembly, blue printing, porting etc). then add the cost of parts:
tomei cams ($1,000?)
tomei valve springs ($400)
tomei full gasket kit (450)
trust sump extension and welding (around $1,700)
nismo timing belt ($200)
tomei cam gears (bought as a set with cams)
Nur cam valley cover/rocker cover and garnish ($380)
Mines cam cover baffles ($200 or so)
then add freight, customs etc to that to get it to aus.
As I said, I have not added it all up to the dollar but I have all the receipts for the new owner and cost is easily past the $20,000 mark.
ASKING PRICE IS STILL $16,500 and is still pretty firm. Anyone seriously interested contact me by pm and we can arrange an inspection/purchase. :whistling: now that the Nur engines are no longer available it would be very hard to build one again like it with all new components.
Hi you can pm me now as I think I have put up more than ten posts mate interested in the whole thing drop in, you've done 95% of the work I just don't have time to case up all the the parts, so if you want to pm me with exactly what you have and haven't got that would be geat
cheers
Pat
cheers
Pat
PM sent. :verymad:
BTW, koyo radiator is gone. sard injectors are gone. sard fuel rail is gone.
EVERYTHING ELSE I STILL HAVE.
my new car will be here in 2 weeks time.
I'm pretty keen to shift the engine now and all the other gear too.
I still have all the gear to make this a drop in prospect and can easily supply a set of injectors, rail and radiator to make it all complete again. All the key stuff is there, engine, turbos, tomei manifolds, inlet piping, ARC intercooler, Trust suction kit, plenum, 6 throttle set-up, front diff, all the external gaskets etc the whole shebang-a-bang. If your in sydney I can even organise it to be installed for you at a number of local shops I deal with for a good price.
There is 20 years of RB26 knowledge in this engine and lots of little tricks that aren't mentioned. :P
  • 3 weeks later...
Hi there,
Would like to know if gaskets, studs and mounts are available with engine.
Please get in touch with me thanks?
There is 20 years of RB26 knowledge in this engine and lots of little tricks that aren't mentioned. :happy:
Where art thou Beer Baron,
I can't PM you yet but wanting to come and take a look at your engine, would like to know what you want for Trust suction kit, Nismo air flows and the Tomei manifolds?
It will be going into a BNR34.
Please get in touch thanks.
  • 2 months later...
Hi Guys, engine is still for sale. I've actually had it "sold" twice but first sale fell through due to buyer not actually having money and recently a buyer I'd stuck a deal with in December for pick-up in Jan decided to do something else (fair enough at least he told me!).
so, engine is up for grabs.
also, Greddy suction kit to suit nismo or standard AFMS (can also be adapted to Z32s easily enough)
Nismo engine mounts
random other parts - so please pm me if interested. I know have my Jun 2.7 engine running and driving it so i'm pretty motivated to sell this engine off.
I also have a used (85,000odd kms) 1993 R32 GTR engine for sale. It's a complete engine like this one from head to sump. It's a late model R32 so has R33 spec crank and oil pump drive. It's in perfect health with 155-160psi compression across the board and was only removed as I fitted a new NUR motor to that car (my old silver R32 GTR - for sale thread should be on here somewhere). Asking price for this engine is $4,300 complete ready to drop in.
  • 3 weeks later...
buy me!! I now have 6 cars, 2 motorbikes, 2 spare complete RB26s and a garage full of bits. I am afraid to go to bed in case my gf kills me while I sleep!!!
Someone but an engine or a car or a truck or something before my short life comes to an end. thank you!
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
