hay guys
what color should i paint my rocker covers on my 26/30.
i have a tomei engine ornament plaque thing but need the covers all painted up.
my plenum will probs be black and the turbo kit all chrome finish.
give me some ideas what u reckon
no yellow or orange please and no stock colors.
i like the mines purple but have found it impossible to find any info about it anywhere.
https://www.sau.com.au/forums/topic/330396-rb26-rocker-covers/
Blue. Crinkle coat finish. Or colour match to the car with crinkle coat finish.
Crinkle coat ftw
nah i dont think blue dude... my car is pearl white so it would be a bitch to keep clean dude. i already thought of it.
Nothing beats the stock red R34 GTR covers.
+1 for Nismo Red Crinkle Coat.
Millennium Jade would be next on the list.
Z-Tune Silver.
Mine's R34 GTR Crinkle Coat.
HKS.
Tomi Blue looks good.
Aqua Green..?
Nismo Fine Spec Engine.
Chrome..?
hmmmm
i really like the nismo fine spec and the z tune is pretty awesome.
i thought the mines covers were purple..
It probably is, just the lighting in that photo, it looks darker.
The Nismo Fine Spec looks like a dark Gun Metal Grey or they have just polished up the Black R32 GTR / R33 GTR covers...
Talk to Chris at Craved Coatings. i got my covers powdercoated Black Cherry. looks awesome in the sun and incredible at night aswell
He can do crinkle coats and a bunch of pretty cool colours going by his website. Net is being gay and can't upload but have pics in my build thread if you wanna check em out
who does the crinkle stuff?
your answer is in post number 10
Was at my engine builders on the weekend and almost walked out with a set of black crinkle coat ones.
They look evil! And will most likely end up on my new engine :)
see :D
Yes Dave, ive actually heard you may have inherited the black 'stealth bomber' covers.
Edited by blitzxtr
