Yeah ill be there!!! I can't wait, soo excited its the 1st time I am able to drift on a track!! wohoo!!! I hope I dont kill my car...so look out for a stock looken black r32 with a blue trust sticker on the back and a lil angled exhaust.
good work! have fun man! i want to get out there and do it myself, but i'm not going to take the skyline out there, its too precious. Next car is going to be more slasher. .
Anyhow, doesn't look anybody wants to meet up.. but if u see a multicoloured 33 there, say hello to the driver (me :()
Work commitments can be the death of a person you know! then again having absolutely -no-work commitments isn't too good either as I'm discovering :D
Anyway, I think its a monthly thing.. so there is always next time. Can't wait to have a look at drift in the real though..
Yeh, im a little "iffy" about taken my car out in this crazy heat we have been getting the past couple of days...but hopefully we get some cloud cover...im really cut i couldnt get suspension in time, so ill be drifting "bodyroll" styles haha..hope the heat does not kill all the power i nearly have too. :D
I was there spectating. great to watch it in the real! Was pretty hot, but everybody who was going seemed to do pretty well. Mostly 180's, few s13, a cerfiro (or was it two?) and about 4x R32, 1x 33 and few aussie cars.. A few were doing it a bit tame and a few oversteering a little too much and spinning out, but guess they were just learning.
white r32 - which one was yours? is it this one??...
if it was u were getting some pretty good action happening! r32-drifter what one was ur one?
I took some vids with my camera and a heap of photos. Most of these are around 3-5meg and 20 seconds or so.
http://www.gamebiz.com.au/other/drift_movi...ellow_capri.avi
http://www.gamebiz.com.au/other/drift_movi...s/white_s13.avi
http://www.gamebiz.com.au/other/drift_movi...hite_r33_03.avi
http://www.gamebiz.com.au/other/drift_movi...ies/red_s13.avi
http://www.gamebiz.com.au/other/drift_movi.../red_s13_02.avi
http://www.gamebiz.com.au/other/drift_movi...ies/red_r32.avi
I got more but I'm on dialup so will take a while to get them all up!
Doesn't look like there is much chance of hitting anything which is a good sign.. when i get my shit together I definitely wanna get out there.. Was good to see that white 33 ripping it up as one of the better ones. I need to buy another car first, while my 33 would be more than up for the task, 33's cost too much to fug up :D
and a 31 skyline.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
