can the cams license be done on the day?? or at the sign in?? Ive gotten my confirmation for the track day in the post... so really getting antsy bout having a thrash around the track
  • Replies 381
Posted Images
Hi Matty,
Where did you send this information and what method of paymen did you do the for the CAMS license? Down the paper-work, just need to get it to the correct place along with the $$.
Cheers
On the last page of the CAMS forms down the bottom is where you send it, and just get a money order from the post office to send with it or a cheque.
All. Watch this space with regards to sign in for sprint only entrants. I am on the CSA committee and am talking with the prez to see if we can come up with something suitable for sprint only entrants to sign in on the morning of the sprint which does not kill us with admin. Hopefully advice to come this weekend.
Be warned that it is likely to come with a requirement to arrive EARLY at Mallala to allow us to administer it with time left for scrutineering.
sent an email off to the address on the site in regards to holding a spot. wont be able to organise payment for a week.
... god that makes me sound like the stereotype of an r31 owner. lol.
i received a call from someone last night in regards to filling out a form with the CAMS stuff on it??? still havent got your email....i think i spoke to Brett or Brad???? cant exactly remember the name
Krishy, that would have been Brent? He is the comp sec. I assume that would be filling in the full entry form for the sprint (Which was held back until the supp regs that are attached to it were approved by CAMS)
Which leads me on to your post Matty. The supp regs and formal sprint entry form are now available as a PDF on the Skynats website. Link here.. http://www.skylinenationals.com/Entry_and_...ls_12_09_10.pdf
It would be preferable for these to be back with CSA prior to the event as the less of these we have to deal with on Sunday the better off everyone will be and the quicker we get out on to the track to have our fun.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
