Hi guys,
Currently looking into running my car in Street Car Competition here in WA, which run primarily under the Group 3D - Sports Sedan rules.
They provide a table of minimum race weight versus displacement and tyre width. After peoples experience as to whether it would be better to have 100kg less weight or 1" wider rims.
The car is 2.6L, and with the turbo multiplier sits in the <4.5L displacement. So with 8" rims minimum weight is 1250kgs, or 9" rims is 1350kgs.
The tyre is a control tyre, Bridgestone RE55.
Cheers
Paul
https://www.sau.com.au/forums/topic/332406-car-weight-vs-tyre-width/
Well....can you get the car down to 1250?
The table you have posted is interesting...there is no tyre width limit based on weight in the cams rules so they are a local addition. They are very restrictive so it will be interesting for the competition.
The best thing to do is to have a look at the front running cars (or those you want to be competitive with), what do they weigh?
Also have a good look at available sizes and prices before you decide....presumably dunlop slicks are the ones to have, they are here.
That's actually a really interesting rule.like Duncan said it certainly would wake up the competition. You need a light car that looks after it's tires well.
I'd try and get it into the 1250kg 8 inch rim category. The extra inch or rim width is only going to help with corner speed something that can be had with well sorted suspension as opposed to slower acceleration and straight line speed which requires more power and possibly less reliability.
Do you know what the car weighs?
WHAT CAR IS IT.......NOT MANY STREET CARS ARE CLOSE TO 1250KG.
Although it's Street Car you can strip out pretty much everything, aslong as you retain the standard bodyshape. Can replace the windows with Lexan, replace bonnet, fenders and boot with CF or fibreglass.
It's an R33 GTS-t, so not sure my chances of getting it down to 1250kg even if I stripped out everything. Currently in the process of removing sound deadening and wiring harness etc.
The front running cars tend to be the Rotaries, even with there additional penalties applied.
Unique1, The car is running 500rwhp at the moment, and has traction issues even with the the 9" tyres at the moment.
Risking, The car weighted 1370kg before serious weight reduction, and that was with an extra passenger seat, so I'd imagine we could get somewhat close to 1250kg, but not all the way there. Then I'd have the option of running at 1250+, or adding back in the weight where I want it, to make it back up to 1350kg.
Duncan, Not Dunlop slicks, Bridgestone RE55s are the control tyre.
Personally I would go the 100kg less....1" more rim is not enough to outweigh (hahaha) the 100kg advantage IMO.
Knowing all about your traction issues :woot: I would look at sorting suspension and power delivery in order to improve in this area.
Hi Ant,
We have improved the suspension from the last time you've seen it, and changed turb to improve the power delivery too. Thinking of going with E85, so I can improve the mid-range, and reduce the top-end power a bit, in order to maintain a bit better traction.
Hi Ant,
I remember you telling me that you changed the turbo but didn't know about the suspension.....I will assume that you went adjustable everything and can now setup the car properly.
Perhaps people with more track day experience running high HP rwd cars can advise further but it will come down to balancing the power with the delivery in order to get traction with the set rim width. Your suspension may need a few tweaks as well. I know that Adz's rwd 32 just pumped out an amazing time at Sandown but he is running much wider wheels than 8-9" and for the most part it was down to suspension settings.
Yep, went from the TO4Z down to a 3076R.
We've spent time tweaking the suspension, but everytime we change tyre brands we seem to go back to square one. At least with a control tyre we'll have the time to keep tweaking small improvements out.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
