One of the best looking GTT with full OEM R34 GTR front end conversion and some brand new after markets goodies. Rare factory sunroof option!! 5spd manual.
Modifications:
Exterior:
-OEM R34 GTR V-SPEC II Front Bar ($800 include respray)
-OEM R34 GTR Front Lower Lip ($650 include respray)
-Z Tune Style Wide Body Fender ($1000 include respray)
-Aftermarket front diffuser ($500 include respray)
-Custom Side Skirt to fit Wide Body Fender ( $500 include respray)
-Custom Rear Pod attached to rear bar ($300 include respray)
-R34 GTR Carbon Fibre Bonnet ($950)
-Carbon Fibre Air Box ($250)
-Modified Bonnet Hinge and Latches ($400)
-Clear Front Indicators
-6 month old 18 Inch Matte Black Monza Japan designed wheels with 85%+ threadGoodYear Eagle F1 tyres ( tyres worth $600 EACH at RRP) 235 for the Front and 245 for the Rear ($3000)
-Nismo Side Spoiler Sticker ($35)
-Tinted Window at 20% $100( Side windows and sunroof only)
Engine: (I purchased these at brand new condition within a year)
-Apexi Air Pod Filter ($160)
-Front Mounted Intercooler ($650 include installtion)
-Trust PE II Catback Exhaust ($1000 include installation) extremely quiet
when idling but build up nice loud tone when you put your foot down.
-Splitfire Coil Packs(Brand New) replaced during 55,000kms service.($650)
-Blitz Turbo Timer ($160)
This car is a series 2 GTT with pop up screen in the center console. The screen can hook up to dvd player as a secondary screen. It has a rare sunroof option and Factory Xenon HID adjustable headlight. It is seriously one of the best looking GTT around and a real head turner!
The car has never been boosted and slight stage 1 mod has been done and is ready for the new owner to promote to next stage of engine mod. Come with service logbook from Japanese owner, RWC and 12 months rego until JUN 2011! Car is always serviced at RE Customs with receipts.
I had only owned this car only a year. Purchased at 54,xxx kms and now only has 68,xxx kms on it. Immaculate condition inside and out and drive like new. It's time to let go as looking for 4 doors car. Really regretful sell.
Price is negotiable. May consider other reasonable offer and swap.
Please pm me if you were interested!
More pictures and info, click here.
very nice car mate, sorry for not posting a genuine inquiry, but i'm very curious as to what is displayed on the screen? Is it like a gtr Multi function display?
oh it supposed to display the gps map n tv but apparently can't work here in aus. It can display mp3 playing status atm. but somehow it could be reuse as a secondary screen by hook up to aftermarket headunit.
  • 1 month later...
  • 2 months later...
  • 5 months later...
  • 1 month later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
