I'm just curious what factory options were available back in the day? For instance, my 1994 r33 gtst has a front mount intercooler and I have no idea what brand it is and where it came from. The guy I bought the car off had it imported with it. Is there any chance it came from the factory? I also have impul bucket seats. I know impul are associated with a lot of nissan cars, any chance these came from the factory?
The reason I ask is I want to put on a Apexi pod and it's apparently illegal to modify two cold air intakes in Victoria because it raises exhaust emissions (can somebody verify this?). But if the cooler came as an optional extra i could argue, should it ever arise, that I have only modified one intake (as the cooler would be stock).
Any advice would be appreciated
https://www.sau.com.au/forums/topic/332956-skyline-optional-extras/
GTS-T come from Nissan with a side mount intercooler.
An aftermarket front mount intercooler would have been installed by the previous owner = 1 intake mod in VIC.
So don't bother installing an air pod.
The stock air box and the panel filter inside is decent enough for about 200+ kW's.
Go for a high flow panel filter if you want but the stock one is still fine... Maybe give it a clean if not done so... :D
Your Impul seats would have been an aftermarket item as well.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
