hey guys just a question, when i reach about 5 and a half revs on which ever gear my car tends to lag, not goinng its full performance is it the turbo or is it that not enough fuel is going through therefore theres a problem with the fuel injectors??.
thanks
https://www.sau.com.au/forums/topic/333397-r33-gts-t-turbo-lagg/
hi newbie here
just wanna ask when does the turbo open/on/operate on a R33 S2 stock.. tnx
Turbo opens/on/operates all the time, when you see boost all depends on the Amount of Throttle and the amount of Load on the motor (In gear, not free revving) this will change though and you can add the size of your fuels system, intake, turbo, exhaust blah blah..
Edited by PaulosECR33
tnx sir.. its a very helpful info.. tnx
turbo will boost from 2000-2500 rpm - hopefully hit full boost around 4000rpm - 4500rpm up to 6500rpm (roughly)
(assuming stock ecu / stock turbo etc etc)
so before 2k rpm the turbo is doing nothing? is that right? also if the car got an intercooler it sure got a turbo right?
please bear with me.. totally newbie! tnx
Edited by DOHC
apologies to the OP (dont mean to hyjack the thread but i feel compelled to answer his question as we were all newbs at one stage)
before 2000rpm the turbo is still running although its not making positive boost pressure.
in regards to intercoolers - generally yes - although u do find some people (i have no idea why) putting intercoolers onto non turbo / non supercharged cars.
if you have any other questions, just PM me - saves cluttering this thread up as its a bit off topic.
Turbo lag means the period before turbo hit its set boost. So if you have a really big turbo you would experience lag before 5500RPMs. Can you detail this lag that you are experiencing?
wrong. boost threshold is the minimum rpm required to reach target boost. lag is the amount of time it takes to reach full boost after planting the throttle above the boost threshold. getting technical but you should know this :laugh:
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
