hey all, i seem to have a really loud induction noise, it sounds exactly as if im using a pod, but im just using the stock airbox, i hate this because id rather hear the exhaust than the loud fsssshhhhhhhhhhhhh from induction, i dont have the snorkel on, but surely an airbox shouldnt sound this loud... could something be loose somewhere letting air escape? it seriously sounds like a pod (i had a pod on my last r33gtst thats how i know)
wtf?
any ideas?
stock turbo
https://www.sau.com.au/forums/topic/333412-realy-loud-induction-noise/
wtf?
any ideas?
stock turbo
check if the piping from the airbox to the turbo is still on the turbo. had an issue with mine where to come off and sound really loud. check all the clips are all on the airbox and the airflow meter bolts that bolt onto the airbox is still on.
No snorkel + aftermarket filter = answer your own question really.
in theory yes, but i have had the exact same setup on my last cars and it was no where near the same loudness, ill check out the piping to the turbo, pretty sure its tight though.
are there any ways to quieten this down? the snorkel dosent fit over the intercooler piping :P
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
