OK, sorry for the lack of updates, but work got in the way for the past few months, and seeing as it finances the project, I couldn't really say no.
BETTER SAFE THAN SORRY
Having seen a fair number of incidents at the track, and also being a requirement for the race category I plan to enter, I finally bit the bullet and went the full cage. Asking around the racers in WA, one name kept popping up for who does the best rollcages. Brad Stacy. Working for one of the top Race Workshops in WA, and also working from home, I got in touch with Brad, and explained my requirements. Brad was awesome to deal with, and having done dozens of cages before I felt confident leaving my car with him.
The cage took about 2weeks, which wasn't bad considering he was doing it in his spare time. I'm really happy with the end result, and would recommend Brad to anyone thinking of getting a cage done in WA :thumbsup:
http://www.bradstacyfabrication.com.au/
Enjoy the pics
PICTURES
X side bar
Roof X bars
Front view
Rear Cage
Cage Rear Strut
Cage Hoop Top
Cage Hoop Bottom
  • Replies 76
Great work Paul,
Good to see Brad sorted Cage out :thumbsup: .
Whats next dude,
new RB30 :rolleyes:
I'm leaving the engine as is for the time being, makes plenty of power. Likely conversion to E85 fuel though, which should improve response and up the power a bit.
was just wondering about this car just yesturday, how long until it gets back on the track???
Potentially it could go back to the track within about 2weeks, but in order to get everything ready to pass scrutineering it will take alot longer. At least I'm back working on the car again, so progress will be made :thumbsup:
  • 4 weeks later...
just getting my battery nerd on, what are you thinking of using?
you can get pretty powerful motorbike batteries, they already use them in race/drift applications anyway
I'm getting a Braille Battery, only weights 3kg :D
http://www.autocraft.au.com/braille/index.html
bit expensive, but that is pretty light, what one were you looking at? how many cca?
are you looking at the lithium ion technology?
depending on the cca you require i'd say a Deka Powersports ETX18L or ETX30L,
they are a AGM technolgy and should have plenty of power and they could even sit around for 6 months and still start the car.
Give Goodchild Enterprises a call and they should be able to give you a good price on one, even tell them Erik from Bitz sent you
  • 3 weeks later...
stock cams will do 450rwhp wouldnt ever use that much grunt really in a track car, plus you would try to retain vct at any cost possible as it is a very good thing to have while tuning.
very clean car mate did you have a dyno sheet from the engine set up on page 1?
i was also supprised at the weight of the doors as well i have mine off at the moments and there feels like enough metal to make a charade out of them.
how much weight do you think you saved by stripping the wiring harnes out of curiosity?
Edited by kungpow
paul have you disabled the VCT to run the big cams?
looking to do this to mine but cant find out much about it.
Hi Tristan, I've got the biggest VCT cams I could find, Apexi 270degs. I think the VCT is one of the best parts of the RB25s. To be honest you'll struggle to find big VCT cams, so you may be stuck with disabling it.
I do somewhere, I will try and get a copy posted up.
At least 10kgs, I have shopping bags full of it.
  • 4 months later...
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
