Hi everyone, just thought id check in and say G'day. I just purchased an R34 Gt-t and i adore it, im looking forward to many useful discussions on here as all us skyline lovers get to know each other and share our knowledge and experience (except me - always dreamed of a skyline but when it comes down to it i sure have alot of learning to do)...lol Cheers everyone....xxxx
https://www.sau.com.au/forums/topic/333876-a-new-shy-girl-from-nsw-south-coast/
Hi elle i'm from nowra allso,you might of seen me around grey green 33,great to see more girls in the liner scene.Oh and welcome. :D
Elle 'n Genelle > both from Nowra > should be easy to remember :rant:
Welcome to SAU!!!
Thanks so much to all of you for your welcoming comments, there is one picture of my car in my gallary (not sure how to use this site properly yet...lol) its not a great pic, i need to give her another bath then ill take some better ones, maybe you guys can have a look and give me some suggestions on what you think i should start on. I used to have a little black Charade that id tricked up, i retrimed the entire interior, did all the painting and electrical bits and pieces on it myself (neons ect), cant wait to start on the skyline but i can tell its definately gana be alot harder than workin on a little simple Charade...lol
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
