I have just finished my turbo conversion in the uk and made 310 bhp and 275 lb/ft torque at 9psi would highly recomend this conversion to any one . Thanks for the idear and info 666DAN with out this forum and your info i would still be driving a 200ish bhp A/N and wanting more power . So thanks again ;) i have added a pic of what she look like .
Nice effort!!! Glad you gleaned some useful info from this thread :P It is worth doing and can be done very well as your numbers prove.
thanks guys just what i wanted to hear, i wont want to do any tuning or boosting, just want low boost to give some decent low down torque that the n/a sucks arse at.... so i should definately use the rb25det ecu, and what turbo will best suit the rb25de, the rb20 or rb25 turbo? and will i have to mod my loom at all for the turbo ecu
If you upgrade the injectors, fuel reg and fuel pump to GTSt spec, then the RB25DET ECU will be fine and be plug 'n' play. Bolt on an RB25DET turbo and run at stock actuator pressure and it should all work a treat.
Don't get a smaller turbo as it will spool *way* too early.
  • 3 weeks later...
It's not so much about the power numbers but the response with running an engine spec like this. Run with an intelligent tune there is no reason why it wouldn't/couldn't be reliable, possibly more economical, and with the sort of power that works well on the street.
That said, do we have any dyno sheets of any description?
Here's a graph of my RB25DET running 12psi to achieve 300hp. It's not overpowering, but very useful and responsive. The dip right at the top end is from pulling ignition to combat knock. I've considered that a well thought-out DE-spec engine with similar power numbers would be even nicer, response wise on the street. Perhaps water-meth is the key to making one detonation proof?
Edited by Dale FZ1
  • 1 month later...
how hard/difficult would it be to take out the rb25de from an r33 series 2 manual, and put in an rb25det engine and ecu?
what would be needed? would all the wiring match up? im guessing it wont....
any help would be great
This is the dyno sheet for my turboed RB25DE at 9psi
Edited by shawny
Hi Shawny,
Nice numbers. What mods do you have on your car? I am a new member here, from Canada, and have been having all sorts of troubles. If you can help me with stuff here, I would be grateful. I have an RB25DE with an R33 turbo on it, Trust FMIC, 370cc injectors, Turbosmart BOV and boost controller, with stock RB20DET ECU and Gredy E-Manage). Everything else is stock from my RB20DET days. Since they are new to Canada (how pathetic this is, lol), not many people know how to fix a Skyline, at least not as much as Australia or UK or Japan.
I am having troubles with idling (The TPS I am using is for the RB25DE, but my ECU is RB20DET, and the AAC valve is not working)....the cars sputters and backfires a lot, it hesitates under load and when I give gas. The power just doesnt seem to be there. Right now, after being dynoed once (260 rwhp), it has started sputtering between 2000-4000 rpm range, and the sudden bog/hesitation is still there. I dont know what is going on. What do you suggest? Also, please do share what youve done to your motor to get such impressive numbers. My motor also has the VCT on the intake side, but I dont know how to activate it with a switch.
Thanks,
Judas
Edited by Judasentinel666
  • 1 month later...
i have a neo st8 6 is it easy to fit a turbo on it i have been told
to Find a R33 with a turbo and fit it... (cheeper option)
and to fit a kit (if i can find one) will be around 13,000 bucks
but its hard to find one because the darn company went in 2 relaps and stop making turbos 4 the
neo st8 6
errr have u not read the start of the post dinobones? all u need is just a stock R34 turbo with FMIC/or SMIC with standard turbo computer and the oil lines tapped and water lines etc....then your all good to turbo and do something with the timing and thats it :P no need 13 000
CHeers
Chi
Munib, are u sure the car is not going into rich and retard, i had same sort of prob when i had a piggy backed na ecu, microtech solved my dramas but some sort of timing control is akll u might need
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
