i wouldn't bother with the RB20 turbo,
The only reason why is that a friend of mine gave me one and an RB25DET exhaust manifold. Both in decent condition..
I'm a uni student, just seeking a few extra KW to offset the slowness the AWD in my R34 gives me. It just need a tad more to be be enjoyable :-)
The Cams are identical, but from comparison it looks like the cam timing is slightly different. Inside the VCT/Intake camgear it actually has bolts to adjust it, my turbo cam gears have a different setting to that of the N/A. Once turbo'd, the dyno shows a bit of a hole on most N/A+T's just above 5000rpm, it is my opinion that it is due to that.
Do you mean the hole's there due to the intake cam gear not being adjusted to DET specs? I've brought my DET parts over to a DE and havent touched the intake cam/cam timing.. Does that mean there is power to be had?
This is my graph on stock management, it has a dip down low and up top, my first thought was that it was R&R but it wasnt. I later found out that the N/A and Turbo models also have different VCT points, it is my theory that the these holes are due to a mismatch in the turbo vct switch and the intake cam gear timing. If you look in the NA+T thread you can find similar graphs on NA's using the stock turbo ECU, but it can be tuned out for those on aftermarket management. This dip wasnt really noticible as far as power delivery was concerned, if anything it just felt a quick second surge of power right up top just before limiter.
I later fitted an SAFC which gained about 10kW once tuned but the graph shape remained pretty similar.
Edited by SKiT_R31
Working for Nissan parts helps. I had a look today and the r33 has definitely the same parts used throughout the head, even the head itself. apart from the larger rocker covers, its all the same.
However i checked the r34 and there are 3 parts in the head that differ.
  • Intake cam gear (which we have worked out)
  • Exhaust camshaft is a different part number. NA-13020-AA010 Turbo-13020-AA020
  • NA use same valve springs 13203-5L300 (all 24 of them). Turbo use different valve springs, note 12 intake springs 13203-5L300 are different to the 12 exhaust spring 13203-5L700 on the turbo aswell, so they are using different exhaust valve springs but the same intake springs...
Edited by central coast person
  • Like 1
  • 4 weeks later...
Almost got everything. Todays bits included a FMIC.
So far I have the turbo, intake manifold, FMIC. Got a high flow fuel pump coming soon as well as injectors (havent paid for them yet).
The turbo im running will be from an RB20DET. I will try it and see what it's like, i've heard a few people do this (low pressure, saab style) with decent results (a bit more power, no lag).
If not I'll just buy a turbo from an R34.
What else are you looking at getting? How much boost are you looking at running?
Apart from me not needing to do any internals as i rebuilt the engine with everything genuine internals (apart from ACL racing bearings) and went up with 40thou genuine pistons.
I've ended up going all out now and have got together:
Greddy Profec B
Greddy turbo timer
Stock R34 turbo, dump and exhaust manfold with all fittings and lines and bolts.
Stock Intercooler piping and BOV
Blitz return FMIC to match stock intercooler piping (didn't want to make a cut under the washer bottle)
Apexi super suction kit for stock turbo setup (not just the budget pod filter)
Z32 AFM
Greddy oil catch can and swirl pot
KoyoRad 52mm
Spitfires
555cc Nismo injectors
Nismo adjustable fuel reg
Walbro fuel pump
Exedy heavy duty
Need to get:
Apexi power FC and hand controller
Kakimoto catback, high flow cat and front pipe
(Maybe will get) Greddy oil cooler and relocation kit
About 6psi is what I plan on running.
Mines a bit budget haha (uni student).
I still need: Injectors, fuel pump, ecu and oil/water lines.
Did you get a exhaust manifold, dump and front pipe with the turbo?
I originally was going to run wastegate pressure but i got over the idea of running 5psi quickly. You might only be able to run wastegate pressure without a boost controller.
Keep us updated.
I've got a GT-Four too mate and am considering a DE-T as well
Keep us updated on how everything goes :)
  • 5 weeks later...
Still collecting parts. If anyone has any of the following parts cheap it would help heaps!
Front pipe
Dump pipe
Cross overpipe
BOV
Oil and water lines for turbo
Greddy E-manage
Thats all I need now.
I've got the crossover pipe come to think of it. And a bov somewhere. Might have the oil and water lines but I think I threw them out.
*EDIT* Right, found the BOV but no turbo lines. Do have a Walbro GSS-342 fuel pump if somebody wants it though? :laugh:
Edited by Hanaldo
With the exhaust stuff, has anyone kept the stock G25T exhaust on with a conversion?
The post only lists front and dump pipe. Doesn;t say anything about anything from the Cat back.
Also is the GTT and GT cat the same? haha.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
