expensive as in $500 dollars expensive for them?I sell them all the time to guys in japan....carbonfibre is $70 a meter and the resin is $50 a litre and you might *** up one or two sets to every one good set you make.Not to mention there hand made so it takes a couple of days to make them.I am working on a bonnet and bootlid at the moment...i will post some piccys when i finish them...Hey brendan pretty right for the pics thanks mate...thanks anyway!About the body stuff I suggest you try the dealer you bought your car from
https://www.sau.com.au/forums/topic/3341-finally-pics/#findComment-57392
The HKS GTR is all carbon fibre, it's just the stickers and stuff on it you can't notice it.
If I had the money i'd buy a set, they'd look cool, and $500 isn't expensive for genuine carbon fibre that's hand made. Just not everyone can justify that sort of money for something like that...but then there's GTR Boy :lol: :lol:
https://www.sau.com.au/forums/topic/3341-finally-pics/#findComment-57848
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
