I just bought a Hanvon Touchpad running Windows 7 to use as a media pc in the car. I got the old Emanage and innovative wideband software to run on it no problem, I just have to find a nice home for it.
I would like to be able to slide/clip it into a holder in the dash and also behind the armrest for the kids to watch their HD movies. As there isnt much realestate left on the dash, it will have to cover my din gauges I assume.
Does anyone have ideas on clipping an Ipad style device to the dash?
Looks like a great unit with HDMI out and 320gig hard drive...
https://www.sau.com.au/forums/topic/334576-m35-dash-mount-media-computer/
  • Replies 66
Fun idea :)
Do you currently have a factory screen in your dash? Would you be willing to replace that entirely with a bracket setup for this? That way you could perhaps keep your din gauges :P
my 'Aftermarket' screen sits more or less where the factory popup system goes, except its fixed (doesnt drop down).. http://img265.imageshack.us/img265/5606/img5802xa.jpg
If you could make a 'grip' style holder for the device, similar to how many GPS holders work, you could mounting a bracket on to that - and thus being able to clip in-clip out the unit. Depends on the size and weight of the unit though.. also not entirely sure how it would look for aestetics when the device isnt in place.
Mounting bracket behind my screen: http://img265.imageshack.us/img265/7616/img5813t.jpg
Grip style device for suction cup GPS thing http://img85.imageshack.us/img85/8656/img5816b.jpg
Its a fair bit bigger than that screen though, I will get some pics in the car...
I like the clip idea, only needs to be held in the corners i guess. Like you say the hard part is making it look good when the unit isnt there.
it's a bit gay....but I suppose if your a yuppy you would think it's cool!!! :ermm:
P.S. Pity about the microsoft shit!!!!!
How are you going to run your software mate? Will the apple run it?
Im not sure yet how hard it will be to tune with the touch screen, probably a pain in the ass, but great for swapping maps.
  • 2 months later...
From the looks of last night, tuning via the ouch screen should be a breeze, don't you think? :D
for those interested you can get a flytouch2 10.2" 1Ghz processor GPS, WIFI 3G running android for $250. bargain.
http://cgi.ebay.com.au/10-2-ePad-FlyTouch2...=item230bcbc949
i think it maybe too big so i am looking at the 7" though no GPS in this unit.
http://cgi.ebay.com.au/7-ROCKCHIP-2818-1-2...=item3cb23e1b91
I am just going to hardwire it into power and use headphone to RCA for audio. Should work a treat.
Though other than the mounting issues.. the next problem is that power and headphone are both on the side of the unit.. so unless you want to see these cables hanging out i need to work out a way to hide them away.. prob will get some nice black plastic or metal..
not ideal though i dont see any other way..
  • 3 months later...
Has anyone figured out how to replace the standard screen with an aussie compatible screen with GPS + still running the fuel economy software.
I'm sure there would be enourmous interest if someone could figure out how to get an aftermarket GPS to fit the stock mechanism so it could still pop up and retract....
I would be first in line.
PS. I have been running searches and this is the closest I came.
If you are using an Iphone, jailbreak it, and plug in into the AUX port and get the software that will show the ipod screen on a monitor.
The reason I ask is that my standard screen has been removed before it came to australia.
Would it be worth buying another second hand sock one + mechanism (i have seen them for $200) and going down this route, or just go a custom install of an aftermarket screen that will do gps?
Have you still got the DVD - rom installed in the glove box?
You need that if you want the economy info on the screen.
Where are you located?
No, the DVD rom is not there, so I guess its useless getting the screen again.
Was the TV an option on the ARX or standard?
I thought it was standard but I have been told it was an option.....
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
