if you go into the gallery and look at some of the forum users rides then that will probably help ;)
R32 - is the smallest of the Skylines ... squarer headlights
R33 - is the beefed up .... commonly referred to as the whale ... if you go into my gallery you can see an R33 GTST. Rounder headlights
R34 - a lot squarer than R33 but jsut as large ..... rear lights: one bigger than other. Headlights very square.
Im sure someone could probably explain it better. Pick up the Autotrader and soon you'll learn the difference in the styles.
Maybe a few diagrams might help...;)
The R32 is a sleeker, yet obviously older design, and can be identified by the crease mark running the length of the car, starting at the front wheelarch.
The R33, as Nizmo stated, is a "chubbier" car than the R32, and can be identified by it's resemblance to a chubby version of an S14 Silvia/200SX...
...and the R34 can easily be identified by the crease mark that is above the rear wheelarch, but not the front. **Notice I included the Nismo vented front bumper on this diagram).
Any more Q's don't hesitate to ask! ;)
All 3 have a GT-R model. R32 & R33 have the GTSt models, R34 has the GTT.
The R32 & R33 (all models) have 2 pairs of equal sized round tail lights. In the R34, the inner tail lights are smaller (like a bloody Ferrari!).
The main difference between the GT-R and the GTs is that the guards around the wheel arches are "pumped up" on the GT-R. It will be obvious when you see a GT-R and a GT side by side.
Rezz: Where those original blueprints for the car snuck out of Nissans R&D department?
Actually they're scans of the original toilet paper sketches I got from "Red Park" the Nissan Museum...
Heres the V35 diagram if anyone was wondering...
...and Carlos Ghosn's original toilet paper sketch for the V35... thankfully it got saved from the flush so we could all sit around and laugh at it...
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
