Hel Stainless Steel Braided Clutch Line Group Buy
I have no idea man. You got a link? I could never find whether it was a replacement of the whole line or just the rubber line. In theory though there is no need to replace the hard lines since they can't expand.
  • Replies 187
Too easy Ben, glad to see the QLD guys are getting them today.
Yeah I wasn't really sure on what the GTR line replaced since it was a different length than the GTST one. But I figured you GTR boys have some weird funky setup due to the AWD hence it being different :P
I think the GTST one replaces the block, but I shall soon see.
Well, I got one for my GTS-t, not the GTR..... Box is marked "suit 32 GTS-t" but I've been looking this morning and I'm mildly confused. lol
Let me know what you guys find?
Oh yeah that's right, you had a GTST kit, my bad :P
My mate has his engine out at the moment so i'll quickly dummy fit the clutch line from the master cylinder and see how it all fits.
Edited by PM-R33
So here is the clutch install on my mates GTST.
As you can see it replaces the entire factory setup :D
Here is the massive factory line removed.
For those kids keeping track of their cars diet here are the results:
Factory setup - 828g
New clutch line - 97g
Weight saving of 731g
Not bad ay :)
It's finished man, hence the pictures above of them fitted.
If I do one again i'll let you know.
Edited by PM-R33
Groovy!
My engine and box is out at the moment so I couldn't get a picture of it in my mind. That's a great weight saving! I'd spend an entire day trying to save that weight elsewhere :D
Yeah it's pretty decent. And in reality it would probably be closer to 800-900g because there would be less fluid used in the new clutch line compared to the amount that runs in the factory line :thumbsup:
Edited by PM-R33
Mine landed yesterday, with the brake line.
Cheers Phil, muchos gracias!
That looks awesome getting rid of all that factory crap lol will be much neater. Will have to put mine in on the weekend. Pics help alot
Thanks again Phil :)
Thanks guys.
I'm going to look into whether HEL would do some custom made braided lines to replace the four brake lines on the firewall (for ABS models) or two brake lines on the firewall (non ABS models) that go from the master cylinder.
No real "performance" benefit but I figured for the good prices we are getting these at it would be a nice looking mod in the engine bay :) I've seen a few pictures of guys that have done it and it looks quite good.
I'll let you guys know if some of you would be interested; I know one of my mates is very keen.
Edited by PM-R33
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
