rb26 main crank journals are 2mm smaller on diameter compared to rb30 so it's anyones guess how you fit rb26 bearings in there. You don't need to do any special trickery to make rb30 blocks hold big hp except get it built properly with quality parts and a good tune.
Edited by Dobz
all rb series have the same main journals, the main journals vary
to make a rb30 bottom end reliable
ARP main stud kit
H beam rods (usually the good ones come with ARP bolts)
Balance and weight match all conrods (some call it blue printing)
other then that they are pretty strong
rb30 cranks already have been nitrided from factory, which the hardness coating is 0.010" thick if you do a 10/10 main and big end grind advised to have it re nitrided
if your running nitro or methanol or both get the piston skirts "tough coated"
Just another question to add to this, but is it worth deburring/polish the inside of the block? Like Tidy up all the casting marks etc? or is this a waste of time? I have been told it helps oil to settle in the sump quiker. Same with oil return from head, and in round the oil filter feed.
felix, just build it mate, lol
mine is a std block not painted, spool rods, cp,s,cometic h/g arp,s acl race bearings, done 3000miles on the motor since it sucked something in and did no5 big end, of that 3000 miles over 1000 miles are on track, i ran it in for 40 miles on mineral oil then it did 8 hours on the dyno and then i took it to zolder/spa and the ring all in one weekend.. mine makes 640bhp/556lbs @ all 4 on 1.5 bar..go for it..
Edited by rockabilly
according to spoolup
they paint the inside with some kind of smooth paint so that the oil slips down faster.....worth looking into !
old v8 trick from the 70's
class F red insulating paint, its great until it peels, but peeling is not overly common. Commercial Diesel's have come factory with this coating for decades.
heres the gear (aussie dealer) if anyone wants to use it:
http://www.ppcco.com.au/fact_sheets/pi/pi_glyptal.pdf
But yeah felix there are many threads on here with all info needed.
Don't overthink, quality parts and screw together-easy as
A good thread to read is MarkOs one, he went from 2.6 to 3.0 and basically kept a running journal as he went
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
