if you went for a twin scroll GT3071R with a 0.78 housing you could get close to 300kw with cams and it would have a stupid amount of response. but this will be an expensive route as you need a twin scroll exhaust housing and you need twin gates to do it properly.
Another turbo that people haven't suggested is ether a TD06SL2-20G for just under 300kw or a T67 for over 300 with standard cams. Both these will need external gates as both the Trust and T3 flanged housings are external gate housings.
  • Replies 79
reason i ask is volk34 had his car on the same dyna pack dyno as you a couple weeks back and made 210kw. then today at the SAU-SA dyno day at willals
his car made 162rwkw. thats a 48kw difference between his 2 dyno runs
sorry to use your car as an example volk
There is something else going on there, in the past with the older version there was around 10% difference between dyna pack dynos and other drive on chassis dynos due to no correction for wheel slippage, but the newer versions seem to be pretty much the same as most mainlines.
Your talking about a 24% difference which sounds to me like something else is wrong. Also 162 would be just under what would be expected from a standard auto R34 (don't know what car his is) or is about right for a stock untouched R33. so what mods is he running, has his car been tuned? is it running more boost? was it running the same boost in Willals dyno?
Edited by D_Stirls
i think he has a auto r34 gtt. as for the other stuff i cant comment because i dont know.
"loksta6" you are now on notice and will receive an official warning..........followed by a ban if this slander towards a business continues.
Your post has been deleted but have attached a link to your warning fyi.
If anyone has an issue with a business, take it up with them but KEEP IT OUT OF HERE!!
thanks for all of your responses, as i had suspected gt3076 with .86 will be the one. i have all suporting mods and an eye out for some poncams. hopefully see and introduce myself next dyno day :P thanks.
i am pretty much going the same way mate
I'd get the .82 again if I was to buy another turbo. Response difference between .63 and .82 would only be a couple of hundred rpm max. And your going down the E85 route so the better flowing rear will make a world of difference when you start running higher boost levels. Come to think of it. Just get the 1.06 :D
after doing a bit more of a research your right Luke......63 and .82 rear housings dont have a world of difference in regards to response.....1.06 is in a league of its own isnt it??? :D
.63 rear housing should see me 300rwkw on 25??? mind you its going to be internal gated
ahh internally gated's a different story. get the .82.. you'll run into overboost issues with the smaller housing and IW.
FWIW mine is ex gated type .63 and makes 360 rwkw so the housing can flow more then 300 rwkw thats for sure.
While on the topic of turbo upgrades, I was looking into mix matching housings, staring with my 2530 ...
I'm thinking of upgrading the compressor side of my HKS GT2530 turbo.
The turbine side of the 2530 atm is a 76 trim (53.8 major - 47.0 exducer) wheel and 0.64AR T3 housing which I was going to keep.
Thinking of throwing on, on the compressor side ...
Garrett T04S upgrade kit
wheel: 59 / 76 / 60 trim
housing: AR70 (rated to 550hp)
Now the 2530 is internally gated. I'm looking for a responsive daily driven turbo for 250+awkw, with enough poke for track days and time attacks.
There is another T04S compressor kit, which may be too big for the 76 trim turbine ...
wheel: 61.4 / 82 / 56 trim
housing: AR70 (rated to 600hp).
Thoughts?
What you are in effect making is a GT2876R, they are a crap miss-matched turbo as the small turbine can't produce enough drive to drive the compressor wheel to full efficiency. The biggest i would go with a NS111 turbine wheel is a 71mm compressor which will give you in effect a GT2871R.
If you remember Ryan was running a GT2871R on his R33 and he was making 250 kw with stupid response. I would keep the T3 housing and buy a GT2871R CHRA and make up what Ryan was running
Garrett elude to the miss-match of the GT2876 when they state on the website;
* Best suited for unique applications such as asymmetric turbo installations
* Not recommended for general performance applications
Edited by D_Stirls
Thanks for that. Now I've got a better starting point to go shopping :D
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
