Spotted this GTR up for auction in NT in a few weeks time
Might interest someone on here
http://www.pickles.com.au/damaged/vehicle/...2018031/lotid-0
I bought a series 4 RX7 in the same conditon about 15 years ago from auction.
Pretty much needed a fully dressed front cut to get ALL the bits needed to fix it.
https://www.sau.com.au/forums/topic/335763-cheap-r34-gtr-engine-bay-fire/
  • Replies 44
take a lot of work to get it sorted. would only really be any good if you had a crashed car to take all the parts out of. basically the whole engine bay will need to be rewired, including headlights, etc.
If anyone is serious, talk to Arron from Importmonster
He just sold his car to re shell a crashed race car, so his old motor is for sale and I am sure you could chase up the wrecked one for the remaining parts like wiring, plastic bits and pieces etc.
Depending on price, I don't think it'd be that bad of a buy.
I personally have "all the parts" (that I can see needs to be replaced) to fix it, just from looking at the damage now.
Not sure how much damage there is on the actualy chassis - warping or the likes.
Hazard a guess, front shocks are gone, engine loom will be shot, inner guards,
- The fire looks contained, hasn't travelled far back - doesn't look like its hit the firewall at all.
Looks bad I reckon cause of the carbon fibre bonnet.
- Look at the radiator, I've seen worst condition radiators in cars that haven't gone up in flames.
Anyone know when this is going up for auction?
- Don't think the lister had an idea when putting it up.
11/01? Compliance date - well it looks date like on the plate.
And should be 6 speed.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
