  • Replies 80
Autobarn dude! u got any fibreglass bonnets for an r32? if so how much?
also how much for a set of Vertex side skirts and rear bar?
I have one only at the moment, satin black one off the orange r32gts we had at autosalon. bit dusty but still fine. it is GTR so you will need to get a grille from D1GARAGE. $300
can get some other carbon and glass bonnets, i will try and get some pics to you. send me your email address.
what type of front bars do you have for the r32 skyline?
I am looking for a Trial front bar like the one on the carmate website.
Thanks
MSPORTS, BOMEX, VEILSIDE, TRUST. We can get the trial one for you through carmate if you prefer not to send money order over. i cannot beat their price on it though as it is one i cant source myself, and would get through them.
The end result is only ever as good as that first decision; save a buck' date=' get wavy thin shit, but spend a little more and get something worth trophies at car shows.
QUOTE']
So true, dodgy kit costs more in the long term and may still not even end up looking right. I had some kit from other sources and had to send the stuff straight back as there was no way i was going to put crap quality kit on a freshly painted car. Autobarn came through with the goods!
hey auto barn im after a rear bar for my r-32 gts-t that would go with my trust front bar.
could you please send me some pics and also after some prices/pics or bonnets too
thanx
[email protected]
were u driving in melb drift, how crazy were tha d1's!
i think the msports rear would look good with the trust front, i just had a look at the orange r32 we have here with trust kit and i looks good. i have one in stock $520.
Ohh, can you do a good price on a two person group buy?
$1395 is the normal price which includes freight/insurance to adelaide. i need to get insurance becuase i have had 2 or 3 damaged in transit and im sure you guys are'nt gonna accept damaged goods. freight is usually $100ea and insurance is $50ea, but if i can get an order of 3 or more i could do them for $1100ea delivered/insured.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
