How Much Psi Can U Run In A Rb20det B4 Hurting It
Murray has the right idea! Or just pretend you're a tow truck driver, they drive around as if it's a race track. Pads will be bedded in in no time! Or you'll arrive at an accident scene quickly...
You know what? I reckon you're on to something.
Sounds like doing a track day will resolve all your issues. -
The rotors only have about 5k on them so I didn't worry about the machining.
Also, if you didn't machine or replace rotors, it will make it harder to bed the new pads properly. It is something I'll advised to do. And yes, I've done it many times before, and will likely do it again, so no judgement here if you didn't replace or machine the rotors.
