Anymore than 10psi on a stock RB20 turbo, and the turbo will die. It's not about PSI either, it's about flow. A bigger turbo will outflow a smaller turbo at say 18psi. A RB20 can generally handle 200kw reliably, I generally don't see people pushing more than 250kw.
Wrong way to ask a question...its not really the amount of psi that will kill an engine...you can run 10psi which is really low and still hurt the engine if support systems are not up to scratch or the tune is off...
Look towards power figures more as a rough guide...a rb20det will happily live making 250rwkw all day every day if all is well around it...start getting to the higher reaches of 200 like around the 280rwkw mark and you will head into slightly more dangerous ground...that said...plenty or rb20s nowadays are making power in that region and still surviving nicely...and they cop a beating on a regular basis too...
I sexed up my fully stock RB20DET with S1 RB25DET Turbo with 16PSI all day, loved it
only mods were oil cooler, fuel pump, fmic, coil packs, ra ra ra usual bs, ecu remap
It is all about flow and the tune not the psi. Pressure is just a measure of restriction, if you get your head flowed, bigger cams, larger exhaust side of the turbo and larger intake then your psi will drop but you are pushing just as much if not more air. Also you could tune a motor running 6psi so badly that it will cook itself if you try.
A better measure of is how much power the engine can make before it goes bang, assuming a perfect tune. I've seen a few 250kw+ rb20s on here last more than a few years but it all comes down to many factors.
If you are making 220kw with a safe tune with maybe 15-20psi I don't see why you couldn't get a lot of life out of it
I want sumthing that's going to cum on boost around the same rpm as a standed rb20det turbo but a turbo that will Handel say 15 - 18 psi
This is a flawed question, you should be asking what turbo for x rwkw with similar to standard response. PSI doesn't mean anything unless you specify the turbo combination. As 15psi on a small turbo will flow similar power to 8psi on a much larger turbo.
Your best bet is a steel wheeled highflowed rb20/rb25 turbo that aren't too much bigger. The lowest HP rating highflow turbos are probably your cheapest option, otherwise a 2530 etc.
These will all make 200-230kw on roughly 16psi+ although you won't have standard response, it will definitely be laggier. If you want standard response I would recommend an rb25 turbo, these can push 180-190kw with a good tune and 12psi, will only increase the lag by about 500rpm.
Edited by Rolls
  • Like 1
I've seen standard CA18's run 56psi and 100+ dyno runs. Standard head gasket, standard NA pistons etc etc.
I didn't believe it when I heard but then I saw it with my own eyes.
What these guys are all telling you is true. You are probably asking the wrong question.
If you want a turbo that can run 18psi and have almost factory response then you need a highflow or a GT2860RS
  • Like 1
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
