Hi guys and girls,
I've recently bought a R32 GTS-4 with an RB20DET. I'm in the process of fixing it up and while I've read hundreds of pages on here and random Google pages i still have a problem with it not making full power.
So i'll start with a background:
RB20DET
RB25 turbo,
FMIC,
Brand new copper spark plugs 0.8mm (BCPR5ES)
ECU Diag came up 55, All ok.
(I think i did it right)- O2 sensor came up as the car running rich, LED didn't flash at all.
So, The car runs fine, it boosts to 10psi and its all happy days. However the power band is at like 3/4 throttle and it runs slower when you open the throttle full. Boost is still the same at 10psi.
The exhaust does "pop" every now and again and i'm pretty sure that's just because its running rich.. The car doesn't misfire as far as i can tell but it's not making much power even when gently getting it in that "sweet spot" it does about 16.5s down the drag strip with a 2.1s 0-60 time. so maybe 120awkw at best?
Is there something wrong with it or would a simple dyno tune fix it? I'm not too keen on going to the dyno just yet as i plan to get a 040 fuel pump + injectors and Z32 afm and do it all at once.
BTW, My name is Steve and i'm from west Brisbane, picked up the car recently and i love it! I get my open license at the end of the year so at the moment I'm just cleaning it up and getting some power out of the almighty RB20 for the occasional track day! I can see myself joining the SAUqld club too.. love these cars.
https://www.sau.com.au/forums/topic/336420-r32-power-drop-at-wot/
The stock rb20 turbo was leaking so the previous owner just put in a RB25 turbo, no idea on its history... Anyway to check for steel wheel/highflow? Pulling the turbo completely out to check would be a pain.. and running high boost and blowing the probable ceramic wheel would be bad.
Also yeh i understand i need a new ECU or piggyback system for it. If it does need a tune, is the stock ECU tunable at all? or ONLY with an aftermarket solution?
Edited by sholm23
A hiflowed RB25 turbo will flow more air at 10psi, than a normal RB25.. and in turn a normal RB25 turbo will outflow a stock RB20 turbo at 10psi. What you're experiencing could be what we call R&R (rich & retard), which is a ECU safeguard to protect the engine as the stock ECU by itself isn't very good at supporting higher than stock power.
That makes sense, i took it for a quick drive and it pulls alot harder ar 5-6psi.. which i'm now assuming is the same amount of airflow the stock RB20 turbo was putting out at 10 psi. Now with a highflowed RB25 turbo at 10psi its putting out more air then the ECU can handle and now it needs a tune? Sounds pretty right to me but im still learning alot.
Heres a picture of the turbo as it sits in the car.. I highly doubt anyone can indentify a highflowed turbo by just the front but its worth a shot... I don't wan't to pull the turbo out of the car to check it because i'm not sure what im doing just yet lol. One thing i notice though is that the old RB20 turbo (i still have it) has double the amount of fins, like the normal 6 fins as shown below but with a sort of secondary fin just below the first, making 12 fins. Is there anyway at all to tell if it is? I really hope its the case but i don't want to push more psi then it can handle and blow it up if im wrong.
Here's what a Hiflowed RB25 turbo looks like (notice how thin the housing has been machined back to): http://www.digi-hardware.com/images/r33PU/pufront.jpg
By the looks of it it's a ceramic wheel, but im not 100% sure.
Well so far i've found that its only the exhaust wheel that is ceramic. Only way to test for sure is to have a look at the exhaust wheel and see if the nut is a 6 point hex (steel) or 12 point hex (ceramic). I've looked at alot of pictures on here of my turbo and some people say its a nylon compressor wheel and others say its a metal one? either way if its a ceramic exhaust wheel the ceramic wheel will go first...
So assuming its a stock RB25 series 1 turbo, at 10psi i need an ECU remap to get full power at full throttle? Done.
Now i gotta figure out if i can run 14psi on stock fuel/ignition setup with an ECU remap...
standard rb20det ecus love 25 turbos . at 11.5 psi the injectors are pretty much maxed and afrs are safe itll be 195 kw at the hubs and run a 13.0 if its in a s13
you checked your fuel filter and pump ? that would do it . not enough fuel up top
i was thinking the same thing, bcpr 6 es.
like everyone has said, get a nistune fitted and tuned or any other aftermarket tuneable ecu, but call your tuner and find out what they like to tune before you go buy one,
Almost certainly just the stock tune giving you grief, although in case it is something like clogged injectors or the fuel pump get it on the dyno and make sure it is not leaning out as this will kill your motor.
Does it blow lots of black smoke when it starts to die? If so then a nistune and a proper dyno tune will almost certainly fix your problem. Don't need the Z32 afm unless you are aiming for 230kw+
Edited by Rolls
I'll change out the plugs tomorrow to a BCPR6ES maybe a 1.1 gap too. Will change out the fuel filter aswell. If i was to put in an aftermarket fuel pump, like a Bosch 040. I don't need a tune straight away do I? fuel pump wont affect anything unless i swap out injectors right? I might get one of those too, just to kill 2 birds with one stone.
I can't afford an Aftermarket ECU for while so i'll try all this stuff first before i get a tune. As long as im not running lean i'm more then happy with lost kw's until then if a tune is needed.
A new fuel pump won't affect the tune at all, the Fuel Pressure Regulator makes sure of that. Though it is highly recommended to change the pump on the safe side anyway, since they are 20 years old, it might be struggling now, so more power won't help it.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
