Hi Guys,
I have been getting into the sprinting and time attack thing lately and have been having a ball.
I have an R33 GTR that i started in and then bought an R34 to be a race car. Anyway the R34 lasted 2 days at phillip island and blew up so thats in the shed for a while until i figure out my plan of attack and cash up again.
Anyway, im back racing the R33 and ran 19.91 at mallala the other week and then my best of 1.18.9 at skyline nationals on Sunday.
So i have a challenge i want to conquer and thought a few of you may have some advice for me.
The back ground of the car is:
1998 R33 GTR Series 3
Low Km
Modifications are:
Power FC (fitted and tuned before i bought the car, no idea on power output)
3" stainless exhaust, very quiet, maybe a bit restrictive but who knows
HKS coilovers never touched or adjusted. Dont even know if all four corners are evenly adjusted
Project Mu 2 piece rotors (new)
Project Mu HC+ pads front
Racebrake RB74 rear pads and standard rotors
Hi temp brake fluid
Rays TE37 Sl 18x10.5
Now running Dunlop DO3G semi slicks, 285x30x18
Battery triangle and tow stickers ;)
Car is full weight and i race with the spare and the jack still in the car.
I have as aggressive wheel alignment as possible with all standard arm and bushes.
So the goal is to run a 1m 17.9 or better.
The rules for this challenge are:
No money to be spent on power parts. (tune ok, must run pump fuel)
Anything bought must also be usable on the R34
Really want to do it with out taking any weight out of the car
Must remain every bit a street car
Must be reliable
So realistically i am hoping to do this with basic alignment etc.
The issues im having atm are:
Understeer in the hair pins and turn 3.
Tyres get up to temp and get sticky about the same time the brakes fade out
I plan to fix the brake issue by removing the backing plates and running cold air ducts to them
The under steer im not sure. More aggressive wheel alignment id say and sway bars i suppose.
I also only want to make 1 or 2 changes at a time to see exactly what they do. good or bad.
Anyway this is where im at and want advice.
Where should i go next?
Matt
https://www.sau.com.au/forums/topic/336707-r33-gtr-development-advice/
Handling improvements can be achieved with little cash outlay by installing adjustable selby/whiteline sway bars.
These also allow you to easily tune your handling by either increasing or decreasing stiffness at either end of the car simply by moving the link from one hole to the next.
Good wheel alignment is another important factor - I would start with the Sydneykid recommended settings and also look at ride height. Skylines do not like being lowered below a set height as it changes the roll centre and suspension angles with adverse effects.
When you have a wheel alignment done get a printout of the final settings to confirm exactly what they are - I have had one so called "good alignment" that on checking had 13mm of toe out on each front wheel (great for turn in but wandered all over the place in a straight line).
The good news is that a lot of suspn components are the same between a 33 and 34 GTR...as victory said above contact someone who knows how to setup the suspn for a GTR and spend your coin on that. My R was running on stock suspn and it just didn't want to turn in - since I fitted adj arms etc and had the alignment settings sorted I have cut at least 1-2 secs off every track I have been to. Just be aware that when you go a more track orientated alignment it no longer makes for a nice road car.
As for your brakes....maybe its the pads. The stock setup should be good up until the 300kw at the wheel mark. I run DBA5000 rotors at the front, stock rears with good pads and fluid and never had an issue.
Modifications are:
Hi temp brake fluid
Must be reliable
Well the first, obvious & easy thing to do is chuck the jack & the spare wheel out. Frankly I am surprised they let you out on circuit with them there. It is 20+kg you don't need to lug about.
Brakes are largely a compound thing. What you plan will help.
It is a GT-R it will understeer. You can only ever half fix it simply because the weight distribution is rubbish.
If you don't have aftermarket sway bars then get some. As hard as like for the rear, adjustable for the front or just plain soft. I would chuck a rear bar at it then think about the front.
As for the street/track thing - forget it. A track GT-R will run heaps of neg camber at the front . I run 5 degrees. Which is a world away from anything you want on the road. So you need to have a think about what you want. You cannot have a neutral car on the track & a nice one on the road unless you change a bunch of things everytime you go to the track.
ok, thanks for the feedback so far. I think i need to clarify a few things. This project is to keep me driving and learning about car setup whilst my r34 gtr gets built.
34 only lasted one day though until it blew up hence back in the 33. The 34 is being caged, dry sumped, built motor, already has ap brakes, pedal box, fuel system etc.
The challenge here is really to go as fast as possible with standard power levels and full weight. Minimal mods. Its more about learning to drive and learning about car setup and what each change makes. Its not a project all about money.
I was told i would not go faster than about 1m 21 with my current setup so to now be in the 18z is very satisfying. but not good enough.
The r33 does not need to see the road as a road car. it just has to look like one as such.
Therefore the alignment etc can be full track orientation (ie, 4 degrees camber if needed). Ride comfort is not an issue neither is tyre wear. It needs to be as fast as possible.
So i suppose the point of this thread is get feedback from guys who actually race these things and what they do to be fast. Also it should be a good read for others in my position.
So stage one will be the brake cooling fixes. Backing plates off and cooling ducts.
At the same time i will be doing the alignment (no sway bars yet) So i want to do front and rear camber and front castor. What alignment ie. camber settings am i looking for and what products do i need. Will offset bushes achieve what i want or do i need arms (cusco, ikeya etc.).
After that i will do sway bars and test it to gauge the improvement.
After that im a bit stuck. I would like to know what other small changes can be made to make this thing quicker. The main thing is to maintain full weight and standard power.
Thanks
matt
Mallala is very hard on brakes. In my r34 with 350 atw and no interior the same setup did not even get close to fading.
Do the sway bars first. They help make better use of whatever neg camber you have. If you do it the other way around you wont learn anything other than doing both of them is better than just doing the wheel alignment.
If you put the bars in first you can then gauge how much of an effect the change in the wheel alignment has. As you will change alignment more than sway bars you are better off doing it that way around.
don't do anything to the r33. use it on the road where it is meant to be.
spend 6 months saving and building the car you bought as a race car, keep it simple and reliable as possible. once it is fixed, do lots of track days, lots of practice
hehe. that was the plan when i bought the 34. The 33 was going to be my nice road car that i could enjoy when i get the chance.
However, i want the r34 to be built to the highest possible quality level and that takes time and money. In the meantime i have to keep racing because im seriously hooked. This little project is just to keep me moving forward whilst the 34 is completed.
That aside i totally agree with you duncan but it isnt going to happen. i have a problem.
Little bit of interesting news. Got out to Mallala last weekend for a practice day and had some success.
Lack of time meant that the only changes were oil and brake fluid but it didnt seem to matter much. I ended up improving my best to attain a 1m 18.3
I ended up achieving this through two key changes. The first was hardening up the rear suspension to full hard and softening the front to 10 clicks softer than full hard. This helped the balance of the car and the understeer reduced a noticable amount. The other thing i did was get my tyre pressures even so they all came up to 36 psi hot. Not sure if this is exactly spot on but it did seem to improve.
The other key change i made was the way i drove my sessions. I did 4 laps with very early braking but aggressive steering which saved the brakes but allowed the tyres to come up to temp. Then i nailed 2 fast laps with hot tyres and brakes that were in their operating range. This translated into an 18.3 and 18.4 lap one after another. I have to thank Simon from Morpowa for his advice here as i think this was the boggest factor in reducing the lap time.
Anyway, thats where im at at the moment. Have Project Mu fluid to try this weekend (big thanks to Autosport and Project Mu here) and also Project Mu h16-03 pads to try. Also have new brake ducts going on so ill see how i go.
Now has anyone got any idea how to beat Martin Donnan in his E85 guzzling evo10? :down:
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
