Got the dump and front pipe done today in a shop in Brookvale... very happy with the work done.... would definetely recommend to anyone.... sorry no pictures as my mobile ran out of battery....
Ended up following the rules and decided to keep one cat....
Edited by FHF
  • 3 weeks later...
  • Replies 270
Will have soon... AM Performance are about to start producing M35 exhausts, dumps and mid pipes, and my car is the test car.
Should have some pics in a week or two, and will hopefully be dyno testing at the end of the month at the SAUSA dyno day.
I'm about to throw my dump pipe right now :verymad:
Lowered the gearbox and all, just can't get to the top bolt nor the one closest to the passenger side. Just no flippin room in there.
Having just re-read some of these posts, there's a couple of tricks I haven't tried yet. So after I calm down I'll go back out & have another go.
There's a bright & shiny new Blitz NUR Spec Touring system to go in, so pretty keen to get these last nuts off.
What price are you charging for your dumps? Would you sell just the flanges?
Mine are stainless, 3.5 inch to 3 inch outlet and very smooth flow. I sell them for $450 heat wrapped and can supply gaskets, stainless bolts, stainless studs with copper nuts and heatsheild for the firewall if you require it. I can sell just the flanges if you like, PM me.
Haha, not the easiest of jobs. Give me a call if you need help, I use 2 long extensions and a universal on the end.
:thanks: Scotty. I have it out now, but that was my problem. I was a bit short one end on the extensions :) . In the end I found a couple of short ones to go with my longer one and it just cleared and I wrestled the nuts off.
After eye fulls of exhaust crap, cut, crushed & bleeding fingers/knuckles, this job as almost taken the shine off DIY'ing, but not quite :rolleyes: . I must say I feel more at home with the electronics.
Haha, bitch of a job but now you have done it, next time will be easier right? You have progressed to the next level mate. :worship:
Haha... next time? I hope there's not a next time. I'm hoping my turbo lasts (cough) for the life of my car so there should be no need to take the dump pipe off again.
Mmm, the next level. Can't wait to get it screwed back together & take it for a spin to feel what the 'next level' feels like.
Are they in Adelaide?
Yes they are, based in Golden Grove.
Check out the Adelaide section of the forums for details on the SAUSA dyno day, you can check it all out then if you want.
Cool. I haven't seen that before now.
It looks like all the spots are taken now. I might come check it out, would love to see what sort of increases come from the dump pipe and exhaust.
Pics?
This is an indication of just how small our ceramic turbine is (and wastegate too I guess). Here I still have one stud to be removed before reversing the process to put it all back with new bits. I'll take a few more pics later.
I'll post the sheets up here anyway, but it'd be worth checking it out. Dunc is going to put his up too, so even if you can't get a spot it'll be a good day.
Is there anyone who has replaced the dump pipe concerned that there is nothing supporting the exhaust till the hangers near the rear diff?
The factory system has a bracket bolted to the bell housing that goes across to the bottom of the dump pipe, and that isn't used now.
Could there be too much load placed on the turbo housing or transferred further up the line? Mine seems very strong but not sure about long term resiliance to vibration etc.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
