AutoSalon 2004 - less than 2-months to go...
  • Replies 218
Guest RedLineGTR
nothing is perfect no matter how much money you have..honestly..the point of the SAU stand at the autosalon as to show people cars that get driven on the road as well...too many cars you see in the autosalon not being driven at all now whats the point of that. We like to show people that come to our stand that monsters like Leewah's GTR get driven on the street however rediculous it may be it still gets driven. I guess we might have some kind of limit to how many cars we can get onto the stand but we will discuss it when the time comes (soon) ;) if everything goes well i will be doing full details to as many cars as i can get done during that time (only external detail not inside) so we will see how it goes..after a good detail you wont be able to see half the stuff on your paint :D Cheers Rob
Guest RedLineGTR
Good luck there..haha i dont have my baby atm so i cant get around using my old mans monster (Misu Magna) haaha. If you enter the MAS i'm should be more than happy to do it if i am helping out this year. Maybe a private detailing session is in order sometime :D;)
Guest RedLineGTR
rob me too ;)
Seagulls…
kamikaze are u even in melb?? "Albury, NSW" eh :D
Keep being funny like that and you will be polishing your cars with your arse cheeks. If all goes well with the autosalon i might organise somthing for vic people, for now i have alot of stuff to sort out, not that much time on my hands :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
