As the topic states
If you were in charge of directing the next FnF movie. What cars would you put in it? What would the plot be? What location would you shoot?
Sorry guys, I'm bored at work and couldn't think of anything else to do.............
  • Replies 90
Posted Images
Base it in the 90's and fill it with R32's, R33's, Silvias, RX7s, Evos, Supra's, 300zxs, etc.
Make it somewhat realistic too. E.g. It would've been so much sweeter if that Ferrari smoked the Supra off the line only to hear the spool of a ridiculous turbo winding up and send the Supra flying past.
i'd like to see more sleepers and less ricers.
also i'd like it to be more realistic as well. none of this neck and neck racing and then having one car drop it back a gear, floor it and just pull away. what sort of cockhead races just to keep up when they have the power to just floor it and blow past them?
Yep that is definetely the most annoying thing that they do. It just doesn't make sense.
In saying if there was another, did you really mean in the next confirmed installment...?
http://www.filmofilia.com/2010/02/04/fast-...tails-revealed/
http://fast-and-furious-5-movie-trailer.blogspot.com/
Edited by TUFF_350
No shit, had no idea it was confirmed!!! The first couple of photos though.... Looks like a movie set in the bronx.. Haha, gangsta as
hahaha is this chick supposed to be pregnant? coz she looks like she's just carrying a basketball under her clothes.
motor is too small
needs more kit
not enough armour
Edited by Munkyb0y
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
