hey for those who have bought and installed a exhaust system on there skyline im sort of interested in getting one but just need to ask in general how much it cost you to put the system onto the car (how much the mech charged), cheers
https://www.sau.com.au/forums/topic/337743-exhaust-installtion-prices-question/
Done this many a time now.
Jack the car up, undo all bolts from turbo back. I had old one off and new one on within the hour.
Be careful where you go if you choose to go the mechanic route, I had an estimated quote of 3hrs labor at $110 per hour to fit a turbo back exhaust!!
If you've got the tools and a free afternoon save yourself the cash :D
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! :)
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! ;)
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :(
Cat-back? Turbo-back?
If it's cat-back it's quite easy to do...
Agree. I put a new cat and a cat-back exhaust onto my gtr whilst it was on the ground in 30mins... Couldnt be arsed jacking it up :blink:
I did a full dump, cat and cat back on my r33 gtst in about 2 hours including time for the WD40 to sink in on the studs.
Cost - nothing! Did it myself without much pain :P
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :)
Exhaust gasket cement.
um lols. i just cleaned the metal between the rear muffler and the piping forward and whacked it back together.
fiiiiine i'll get some cement and do it properlike
Using the theory that a leaking exhaust flows better than one with no leaks? :blink:
I used gaskets and cement, but originally when I installed it with AbboBob (ex SAU president), he said you can get away with vasalene if the exhausts fit up close enough, the vasalene will attract some of the carbon from the exhaust, the vasalene will then pull the carbon into any depresions and keep a hole sealed up (assuming it is only a small hole).
It worked for a year, untill I was bored and randomly decided to cement it up, I was skeptical at first but it worked for a year that I know of.
Best to do it properly though from the beginning, a good job will save you time in the long run
Call an exhaust shop.. Tell them what your interested in.. Get a price.. done..
YUp this is the easiest, and sometimes even the cheaper alternative, especially when you break the dump pipe/turbo exhaust flange bolts in the turbo flange and depending how unlucky you are you could be up for a turbo out job just to be able to drill the bolts out
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
