What Size Is Your Cat-back Exhaust?
69 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Im just curious what everyone's exhaust system is, this is for R33 gtst only, and just the cat-back size, not the dump/front or cat.
ive only done it up to 3.5" because im referring to street cars, not trackies.
https://www.sau.com.au/forums/topic/337753-what-size-is-your-cat-back-exhaust/
I know its not a r33 but, i had a HKS super dragger cat back on my rb20det and it was sooo quiet, loved it, however its now on my 25-30combo and nothing i do can shut it up hahaha
oh and i think its over 4" tip... but about 10 barrel
Edited by -_-StRyDeR-_-
Keep the 3.5 change the rear muffler.
ive changed it,
A you cant get 3.5" ovel mufflers
B 3.5" inlet cannons are hard to find that dont have the 4.5" tip (which is the part that makes it drone)
i have the xforce 3.5 in, 4.5 out, and its deep and shitty sounding
is there any benafit of having a 3.5inch system when your pulling about 170rwkw? i have the 3.5 and i hate my exhaust note...
at 170kw a 3ich or 3.5 wont make a difference, what type of exhuast is it reasoanator in middle with a cannon or oval muffler at the rear?
it has a hotdog in the middle and cannon on the back, thinking of taking the hotdog out...
ive changed it,
You can get 3.5" oval mufflers, i have a 4" in/out oval muffler, very deep note.
magnaflow make them in their race series range. All stainless, exy but.
there is other ways to fix the note.. i had a 3.5 inch dump/cat, to a 3 inch hks exhaust that megaphoned out to 90mm just before the muffler, it sounded lovely with a 3inch dump but had a horrible drone with the 3.5 inch. replaced it with a dual 3.5" xforce muffler with a section rewelded so it was full 3.5", it is very quiet and no drone, a touch louder than a stock exhaust.. the only problem im having is because of the second oval muffler is where the resonator would usually sit, it does sit a bit closer to the ground
Jarrod
ive changed it,
The tip has nothing to do with the drone, it is due to the muffler size construction and number used, if you have a 3.5 system with a single straight through muffler im not surprised it drones, your best bet is to get another inline oval 3.5" straight through muffler and put it in the middle of the exhaust, should quieten it down quite a bit removing the drone and bass.
I had 2 straight through 3" mufflers on a 3" system and it was almost as quiet as stock, removed one and it has a very nice note now, not too loud and droney but not too quiet either. 3->3.5 is a reasonable size increase so I think you will find 2 mufflers will make it sound a lot nicer, most workshops will change it out for a plain resonator if you find it is too quite for not much more money.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
