  • Replies 73
Yuck, hideous viscosities! Really shouldn't be running more than 10w40 in an RB, 15w50 at the most if you do a bit of track work or have loose/worn engine tolerances and blow smoke on a 10w40.
Why would I be kidding? I run it on my RB25DET & SR20DET and both engines love it.
10W40 seemed to 'go missing' on my SR which see's massively high revs and reasonably high oil temperatures. 15W60 keeps my RB happy and quiet.
thought you only blow smoke due to the car running rich...is it a different smoke you blow with bad oil?
are they very old engines?
The RB25DET is 12 years old, not rebuilt and ~150,000km old. The SR20DET is 13 years old, not rebuilt and ~90,000km old. Neither blow smoke. Both have excellent compression and make the power I'd be expecting from them.
I just find the thinner oils break down far quicker and end up thin and watery by the next oil change. The slightly thicker oil gives me a quieter engine and I drain almost exactly what I put into them out at the next oil change. A good number of 10W40 oils contain a lot of friction modifiers to achieve the desired viscosity, they're not fantastic for the engine.
to answer your question i use castrol edge 10w-60 since its been recomended by my mechanic...
Lots of people on this forum seem to be using this oil in there RB's, including some pretty serious setups.
The oil thing has me sooo confused.
That's smoke from unburnt fuel when the car is running rich. Yes, it is a different when you burn oil, and it's caused by worn seals/tolerances...e.g. piston rings or more commonly in these cars, turbo seals. The "solution" besides rebuilding, is to use a thicker oil which takes up the tolerances between moving parts. But oil does need to circulate around moving parts, particularly on startup where most engine wear occurs. Oil is at it's thickest here, so this is where a 10w is a nice balance for an RB engine.
If you're confused about the oil thing Harey, read and read and read this thread - it's lengthy but there's a bit of consensus towards the end.
http://www.skylinesaustralia.com/forums/Go...&start=1760
I did type something earlier but lost it when my internet crashed.
Black Smoke = Unburnt Fuel, not too bad
Blue-White Smoke = Oil, bad. Worn rings, valve stem seals or blown turbo.
White Smoke = Water, bad. Blown head gasket.
More confused that some people strongly recommend 10W40 and others 10W60. Seems like a big difference to me!
have you spoken to your mechanic? talk to him and listen to him...thats what i am doing...peace of mind and you can trust they know what they talking about....everyone will have different opinion but oil is oil and if your car runs good with the one you using stick to that...thats what i would do.... :)
Most mechanics don't know a great deal about the finer points of oil. Well from my experience working in the industry, most get it very wrong and tend to use only the oils they have in stock (most mechanics keep 2-3 engine oils at the most) :)
But there isn't really such a thing as a bad oil, only a better performing or worse performing oil for your application. Thus what your mechanic recommends may not be perfect for you if he/she has never tried a different oil in your vehicle.
But I do echo what Harsh says in the latter...try a few different oils and then settle upon the one you feel is doing the best job, you won't kill your engine by doing this. 10w40 is a good place to start in an RB.
Most mechanics don't know a great deal about the finer points of oil. Well from my experience working in the industry, most get it very wrong and tend to use only the oils they have in stock (most mechanics keep 2-3 engine oils at the most) :(
YAY!!! i was right in something :)
Thinner oil is better for turbo(s) as they are less likely to dried up and clog up inside the turbo and associated hose that running inside and out from turbo(s). so yeah I use Mobil 1 fully synthetic. Won't cost as much as Motul 300V.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
