  • Replies 73
Yuck, hideous viscosities! Really shouldn't be running more than 10w40 in an RB, 15w50 at the most if you do a bit of track work or have loose/worn engine tolerances and blow smoke on a 10w40.
Why would I be kidding? I run it on my RB25DET & SR20DET and both engines love it.
10W40 seemed to 'go missing' on my SR which see's massively high revs and reasonably high oil temperatures. 15W60 keeps my RB happy and quiet.
thought you only blow smoke due to the car running rich...is it a different smoke you blow with bad oil?
are they very old engines?
The RB25DET is 12 years old, not rebuilt and ~150,000km old. The SR20DET is 13 years old, not rebuilt and ~90,000km old. Neither blow smoke. Both have excellent compression and make the power I'd be expecting from them.
I just find the thinner oils break down far quicker and end up thin and watery by the next oil change. The slightly thicker oil gives me a quieter engine and I drain almost exactly what I put into them out at the next oil change. A good number of 10W40 oils contain a lot of friction modifiers to achieve the desired viscosity, they're not fantastic for the engine.
to answer your question i use castrol edge 10w-60 since its been recomended by my mechanic...
Lots of people on this forum seem to be using this oil in there RB's, including some pretty serious setups.
The oil thing has me sooo confused.
That's smoke from unburnt fuel when the car is running rich. Yes, it is a different when you burn oil, and it's caused by worn seals/tolerances...e.g. piston rings or more commonly in these cars, turbo seals. The "solution" besides rebuilding, is to use a thicker oil which takes up the tolerances between moving parts. But oil does need to circulate around moving parts, particularly on startup where most engine wear occurs. Oil is at it's thickest here, so this is where a 10w is a nice balance for an RB engine.
If you're confused about the oil thing Harey, read and read and read this thread - it's lengthy but there's a bit of consensus towards the end.
http://www.skylinesaustralia.com/forums/Go...&start=1760
I did type something earlier but lost it when my internet crashed.
Black Smoke = Unburnt Fuel, not too bad
Blue-White Smoke = Oil, bad. Worn rings, valve stem seals or blown turbo.
White Smoke = Water, bad. Blown head gasket.
More confused that some people strongly recommend 10W40 and others 10W60. Seems like a big difference to me!
have you spoken to your mechanic? talk to him and listen to him...thats what i am doing...peace of mind and you can trust they know what they talking about....everyone will have different opinion but oil is oil and if your car runs good with the one you using stick to that...thats what i would do.... :)
Most mechanics don't know a great deal about the finer points of oil. Well from my experience working in the industry, most get it very wrong and tend to use only the oils they have in stock (most mechanics keep 2-3 engine oils at the most) :)
But there isn't really such a thing as a bad oil, only a better performing or worse performing oil for your application. Thus what your mechanic recommends may not be perfect for you if he/she has never tried a different oil in your vehicle.
But I do echo what Harsh says in the latter...try a few different oils and then settle upon the one you feel is doing the best job, you won't kill your engine by doing this. 10w40 is a good place to start in an RB.
Most mechanics don't know a great deal about the finer points of oil. Well from my experience working in the industry, most get it very wrong and tend to use only the oils they have in stock (most mechanics keep 2-3 engine oils at the most) :(
YAY!!! i was right in something :)
Thinner oil is better for turbo(s) as they are less likely to dried up and clog up inside the turbo and associated hose that running inside and out from turbo(s). so yeah I use Mobil 1 fully synthetic. Won't cost as much as Motul 300V.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
